E-Class (W211) 2003-2009
03 E500 New Wheels Help!
Old Jan 26, 2014 | 04:06 AM
dennishuynh80's Avatar
2003 E500 Sport and 2004 E55 AMG
I'm planning on getting new wheels for my car. I'm currently looking at 19x9 in front and 19x10.5 on back with 235/35 fronts and 275/30 on rear. I still can't decide on which ET i should get..... my car is lowered and don't want the wheels to rub when i turn. help would be appreciated!
Attached Thumbnails 03 E500 New Wheels Help!-1003069_800143773344565_906422596_n.jpg   03 E500 New Wheels Help!-1515008_800143753344567_487605440_n.jpg
Old Jan 26, 2014 | 04:31 AM
Inspiredbenz's Avatar
SOLD W203..CURRENTLY DRIVING W211
As far as i know 235 should be good in front and any higher then 275 in rear you will have rubbing issues sum other members im sure will chime in on ET
Old Jan 26, 2014 | 03:19 PM
LemonSqueezy's Avatar
14 550 sedan
I run 19x9 et37 with 245s up front. 235 is starting to stretch it and doesn't suit my taste.
Old Jan 26, 2014 | 04:38 PM
AMGAffalterbach's Avatar
2014 BMW M235i
Agreed, 235 will NOT suit a 9 inch wheel, it will be way too stretched. A 255 or a 245 in the front would be much better. A 295 out back would probably rub unless you roll your fenders, however I know that's the case on a 20 inch wheel so not sure if it's the same with a 19 inch wheel. As far as wheel choices are concerned, it all depends on how much you want to spend and the look you're going for. I love Vossen wheels but I'd never put them on my car since the roads here are so bad...
Old Jan 26, 2014 | 07:19 PM
i'm currently running 18x9 with 245/40 all around. i want my wheels to be somewhat flush with my fenders. my rear quarter panel is rolled. so far, my only problem with my front wheels are rubbing when doing a u turn. First picture is my front and second is my rear.
Old Jan 26, 2014 | 08:01 PM
2014 BMW M235i
Really? What offset because I ran 245/40/18s previously and they did not rub on the front...
Old Jan 26, 2014 | 10:15 PM
JunkYardBenzzoo's Avatar
2005 E320
Very interested in this info. Was looking at some blacked out AMG wheels that came off a CLS55 with following specs: Front Wheel Size: 18" x 8.5" 25mm offset, Rear Wheel Size: 18" x 9.5" 28mm offset, 5x112 bolt pattern. Tire size: front tires 255/40/18 rear tires 285/35/18. Anyone know if these would work for me? What is ET?
Old Jan 27, 2014 | 03:36 AM
came to a conclusion. 19x9 with 235/35 ET 32 and 19x10.5 275/30 ET 35. I just don't want my front wheels to rub when i turn....
Old Jan 27, 2014 | 10:44 AM
Craftysince86's Avatar
W211
lol
up front i'm at 19x9.5 +10 with a 215/35 <-- reason i don't rub
my rears are 19x11 +25 with 245/35 <-- also don't rub
Old Jan 27, 2014 | 12:00 PM
09W211's Avatar
2009 W211 E350 AMG Sport PKG
Originally Posted by Craftysince86
lol
+1, but we're a bit extreme.
20x10 + 35 225/35
20x11 + 35 245/35
If you're on 19's and running a 40 series tire, it's probably too tall. You probably want to stay in the 30's for ET if you dont want to stretch tires and rub.
Old Jan 27, 2014 | 10:53 PM
2014 BMW M235i
Crafty and 09W211 are hereby banned from answering normal people questions regarding tires hahahaha
Old Jan 28, 2014 | 08:29 AM
kompression's Avatar
2005 c55 AMG, 2006 Kleemann E50 K, 1997 Acura-CL Custom
TIRES TIRES TIRES!!!
I've been dealing with TIRES for the last month.
Currently running 285/35/19 10" rears and 235/35/19 8.5" fronts.
Also have 275/35/19 rears and 245/35/19 fronts
Also have 255/35/19 for the fronts.
I think the 235's are too skinny for the front. but they dont rub.
The 285's rub a little but I just need to adjust the lowest ride height with the star computer.
Had some nail and screw battles with the recent construction here in Vegas.
Also had a Falken FK452 245/35/19 that was officially defective..Falken is refunding me for 2 toyos I had to get because they dont make the Falkens anymore.
So DONT BUY FALKENS!! SEE PIC.
Old Jan 28, 2014 | 10:02 AM
W211
dang that's ****ty about that tire, i've rolled tires with -4.5 degree a camber for over a year that looks better than that
if you don't want to rub, and don't want to go smaller tires you're going to have to either roll/pull fenders, more camber, or raise your car
low aggressive fitments require all three: stretch, pull/roll, and camber
Old Jan 28, 2014 | 12:02 PM
09W211's Avatar
^ What he said. Unfortunately, you can't have it all. Somethings got to give if you want to be low and aggressive.
I've had -3.5 camber for a while now and haven't had to replace tires yet.
Old Jan 28, 2014 | 12:41 PM
W211
i run -4/-4.5 and i barely flipped my tires for the first time this month, been on them about a year. camber wears but not nearly as fast as toe, get some oem caster bolts to fix the right pull and just stay on top of everything and you will be fine.
