E-Class (W211) 2003-2009
What spark plugs should I get for my 2003 e500 sport
Old 01-29-2014, 11:06 PM
john0183's Avatar
2003 E500 sport
Hey guys I am new to this forum I am trying to replace my spark plugs and wires can anyone tell me which ones to get and what plugs to get I would really like to either try to diy if it's easy or purchase the parts and bring it to my mechanic can anyone help me out and which is a good place to get them at a good deal thanks help is appreciated .
Old 01-29-2014, 11:19 PM
Craftysince86's Avatar
W211
i did OEM wires with NGK Laser iridiums... much happier running these plugs over the stock one.
very easy DIY
Old 01-29-2014, 11:35 PM
AMGAffalterbach's Avatar
2014 BMW M235i
I second that, I did NGK Platinums (apparently the Laser Iridiums were not a correct fitment according to NGK, but I think that's probably incorrect) and I'm happy with them. They're one of the top manufacturers and most expensive, not by much but the few extra dollars you spend you definitely get a good plug.
Old 01-30-2014, 12:23 AM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
+1^ NGK for sure
Old 01-30-2014, 02:51 AM
john0183's Avatar
2003 E500 sport
Does anyone know of a DIY thread on these and is there a specific torch wrench for to do it so you don't over tighten the plugs.around what's the cost of doing plugs and wires. Thanks
Old 01-30-2014, 02:55 AM
mercedes4ever's Avatar
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
http://www.ebay.com.au/itm/like/1309...iphx=1&lpid=94
Old 01-30-2014, 02:58 AM
27Nm (20 ft/lbs.), do not use any anti seize.
Old 01-30-2014, 03:00 AM
http://www.ebay.com/bhp/mercedes-spark-plug-tool
Old 01-30-2014, 09:15 AM
jandmtv's Avatar
2010 GL450
I too can not find the proper ngk laser iridium plugs for my car. Yet I see a lot of people claiming that's what they use.
Old 01-30-2014, 09:38 AM
W211
just pull the engine cover and intake ducts, then it's just like doing any other spark plugs. there is a two per cylinder, and the wires come lettered so you know which goes where because they are two different lengths in the front and rear cylinders.
why would you not use anti seize?
i'll get you the exact part number for mine when i get home, i still all my receipts from anything i put in my car
Old 01-30-2014, 10:44 AM
john0183's Avatar
2003 E500 sport
Thanks guys on the forum I kinda new I rather DIY then pay someone and don't really trust to many people with my car .
Old 01-30-2014, 11:30 AM
jandmtv's Avatar
2010 GL450
A part number would be great crafty.
Old 01-30-2014, 03:32 PM
Modern plugs don't require it, they have a special coating on the thread. Anti-seize can work its way into the cylinders, causing carbon build up & plug fouling.
Modern Plugs do not require anti-seize, they have a special coating on the threads. Anti-seize can foul plugs & cause carbon build up at the top of the pistons.
Old 01-30-2014, 03:35 PM
These are the correct plugs OEM;
Mercedes Spark Plugs (Set of 16) - Bosch FR8DPP33X16
Old 01-30-2014, 04:39 PM
starbrite's Avatar
2004 E320
Any idea how to use that wrench ??
Old 01-30-2014, 05:40 PM
Arrow
Old 01-30-2014, 05:53 PM
starbrite's Avatar
2004 E320
Thanks, however, nothing in that video re the wrench. He just pulls the wires off the plugs by hand.
Old 01-30-2014, 06:05 PM
W211
NGK 4696
Old 01-30-2014, 08:46 PM
jandmtv's Avatar
2010 GL450
What years will this fit? My E350 is a 2009.
Old 01-30-2014, 08:47 PM
jandmtv's Avatar
2010 GL450
Umm that's coming up as a glow plug for a Alfa Romeo.
Old 01-30-2014, 10:02 PM
This video should help.
Old 01-31-2014, 10:04 AM
W211
**** i'm sorry i have no idea why i put 4694
i used the NGK 4696
http://www.ngk.com/product.aspx?zpid=9779
as far is it fitting your car i am not sure, i have a pre-facelift 211
Old 01-31-2014, 10:13 AM
jandmtv's Avatar
2010 GL450
What year is yours?
Old 01-31-2014, 10:16 AM
W211
2003 E320
Old 01-31-2014, 10:20 AM
jandmtv's Avatar
2010 GL450
I just checked the specs on that plug. The gap, heat range and reach do not match requirement for mercedes plugs. I might just go with the laser platinums.
Quick Reply: What spark plugs should I get for my 2003 e500 sport
