White smoke and unstable engine work on startup (270 cdi)
Can you suggest what could be the problem with my car(270 cdi, w211).
Sometimes, on startup engine(not so cold start) for a few seconds(5-10) there is white smoke from behind the car and engine is not working stable. Looks like one or more cylinders not working. Also there is a strong vibration from engine.
This happen not every time, but regularly. I checked antifreeze level, it's constant. Engine oil is also constant.
What could be?
If there is a problem in injector, how this could bring problem to head gasket or engine oil? How serious is this problem?
I'm happy when there are people who spend their time to help others.
About my problem, as i said .. the problem is repeated, but not every time. After engine start, after 5 to 10 sec. everything is ok. If i push the throttle in this period of time when engine is vibratihg, white smoke appears from behind. Engine is clear, on the top of it.
You said injector(s)... Try to clean them with "bardahl"?
Engine probably runs smooth when warm, correct.
Good Luck
I checked engine oil, coolant .. level is ok.
I replaced broken plugs months before. There isn't error when check with DAS for glow plugs.
If this condition (white smoke) is on a warm engine and smells of diesel then you have an injector leaking into the cyl when shut off and when restarted the excess diesel is not burned at first because of the rich condition but soon fires 5-10 seconds after start.
This also could explain the rough idle on cold start.
2 Glow plugs are easy to check, remove the power wire going to each glow plug and check for continuity (resistance) from the power terminal of the glow plug to the engine block, you may still have a glow plug issue.
As others have stated smell the white smoke when this happens, sweet smell is antifreeze which will form a white cloud out back and does not dissipate quickly, diesel smell is unburned atomized diesel fuel and should clear fairly quickly behind car.
What is the mileage?
Any leakage around the injectors?
I think, it's smells on diesel.. also it's dissipate quickly. On cold start(morning now in Bulgaria is around 0 ° C, 32 degrees Fahrenheit) i don't have this problem. My car has 200k km(~130k miles)
