HELP! P0101 code + car shutting off
I got a check engine light, scanned it, came up with bad MAF sensor, the car was running rough. So I bought an aftermarket MAF off ebay, installed it and then started the car and all was fine for the first 5 or 10 minutes then the engine was very rough, started jerking and eventually shut off. I figured it was a faulty maf, returned it and bought an oem bosch unit online. Meanwhile I reinstalled the old maf until the new one came in and it was fine. I finally got the new bosch unit today, I installed that and right off the start it was rough, drove smooth for 5 minutes but the moment I stopped, the car shut off. Everytime I started the car it would rev itself and then shut off, I scanned the car and got P0101 which is the maf again. Are all these MAF sensors that i'm getting faulty or is there another issue? 2 units and the same problem, either I have really bad luck or there's something else. Could it be the crank position sensor?
Sorry for the winded post, I don't know what to do, please help.
Of course, it is possible you mananged to be unlucky enough to get 2 bad MAFs.
That's about the extent of what I know regarding the MAF. Hopefully someone else with more knowledge/experience will chime it.
Hope that makes more sense.
Since both new MAFs made the problem worse, are you certain you ordered the correct part?
I am positive I ordered the right part, part numbers match, I triple checked everything was right when ordering the bosch unit.
