E-Class (W211) 2003-2009
EXHAUST QUESTIONS!
Old May 15, 2014 | 02:02 AM
AMGAffalterbach's Avatar
2014 BMW M235i
Is the E240 true dual exhaust all the way back?
Old May 15, 2014 | 02:07 AM
D.ORiGiNAL's Avatar
03 W211 E240
Yes it is!
Old May 15, 2014 | 05:32 AM
2014 BMW M235i
It should work just fine then, I think the exhaust setup is the same with primary cats -> secondary cats -> resonators -> mufflers. Obviously you won't get the same sound as a V8 and you might have to modify your rear bumper for the quad exhaust tips but other than that I think you should be good. If you can post a picture of the underside of the car under the lift I can give you a definite yes or no.
Old May 15, 2014 | 05:47 AM
D.ORiGiNAL's Avatar
03 W211 E240
Very helpful man. Thanks! OK I will do that.
Old May 25, 2014 | 09:18 AM
mackadoo68's Avatar
2007 Mercedes E350 4matic Sport
Its my understanding that the e350 catback exhaust is very restricted from the factory. I was informed that you can somehow increase the hp's by releasing the catback but not compromise the sound very much at all. What exactly needs to be done & approx how much? Thx
Old May 26, 2014 | 01:35 AM
2014 BMW M235i
This is an age old controversy and debate but I will give you the synopsis. Exhaust systems on naturally aspirated engines such as the E350 and E550 work on the principle of exhaust scavenging, meaning that there are low pressure and high pressure zones in each exhaust pulse produced by the engine. The trailing low pressure zone along each pulse helps "pull" the subsequent wave out faster, a principle called exhaust scavenging. That's the reason, other than sound, it doesn't make sense to put a 3" exhaust all the way back because you lose the benefit of scavenging and you end up producing less low-end torque and potentially less power overall. I had a ricer once tell me more air in and more air out is best, but that's not true at all. For turbocharged cars, that work off of exhaust gases and dump down into the exhaust setup, they act like a low-pass filters across the system and don't produce pronounced pulses in the same way a naturally aspirated engine does. That's why some monster builds with turbos have virtually straight piped exhaust or open downpipes because they don't want the restrictive downpipe and cat-back setup. This is different with N/A engines, and is often referred to as "necessary back-pressure." Well back-pressure is not really good in any situation, but it's really a misnomer because people refer to exhaust scavenging as back-pressure often incorrectly, which it kind of is, but it isn't the same principle they're referring to.
To answer your questions as to what can be done, I'm sure complete systems from Meisterschaft, Kleemann, Eisenmann or the like will help increase power, more torque than HP I would think, since they are designed with these considerations in mind, but the results will only be marginal on an otherwise stock car. The best thing you can do is get long tube headers for an N/A engine. However, being 4-Matic this is more challenging for you and probably doesn't make sense anyway. Headers are pretty expensive.
Old May 28, 2014 | 10:34 PM
  #32
njmaxpayne's Avatar
2008 e550
ok so my exhaust quest is over.i took a shot and the result was Way Beyond my expectations!!
I replaces my mifflers with a Vibrant 1141 Ultra Quiet resonators.But don't let the "ultra quiet " full you LOL...that **** sound vicious....like a C63 on steroids....i'm blown away from the sound quality.....no drone what soever,its for that exotic super car sound...its unreal...i love it.they cost me 190$ and 150$ for labor reusing stock tips and my shop even tucked them in behind the bumper kind of tilted so u dont see anything but the tips.nothing is hanging down like the stock mufflers....i'll post picture later on....here's the best video i was able to take w an iphone....ufcorse that video does not even get close to what it really is in reality....quiet at cruise but when i step on it i see ppl turning heads and looking in their mirrors what that is...oh and driving it on auto/manual is where that baby sings...(shifting at 3-3300rpms)...i know i'm too much lol but can't be happier with the turnout.here's the video and i'll post pics later.
http://youtu.be/DLQ1mqA7dJc
my serup is:all 4 cats,resonator delete/magnaflow X-pupe pipe,vibrant 1141 muffler/resonators,stock tips.
Go for it.I prommise you'll love it.i'm in atlantic city NJ,if any of u guys live close and want to hear in person and decide on exhaust let me know we can meet up and u can hear for yourself!
Old May 29, 2014 | 01:51 AM
  #33
2014 BMW M235i
Sounds quite a bit like the muffler delete and resonator! I like the sound a lot, good work and thanks for posting a video.
Old May 29, 2014 | 09:37 AM
  #34
njmaxpayne's Avatar
2008 e550
trust me its NOT quiet at all....it sounds wicked.that video do no justice.crappy iphone video quality.and BTW before we welded on the resonators,i started it with the mufflers deleted to see how it sounds w muffler delete,man that shait sounded like a tracktor with exhaust leak LOL...horrible.Like i said in person its really really loud,but not abnoxious and annoying....it's awesome.
Old May 29, 2014 | 02:49 PM
  #35
Buelligan's Avatar
2005 E500
My days of loud exhausts are over, but that does sound nice. I like it.
When I was younger, I never thought I'd have a 4-door car let alone one with a stock exhaust. Things change. I love that Mercedes calm and quiet now.
Old May 29, 2014 | 04:51 PM
  #36
pinebaron's Avatar
07 E320 Bluetec
+1
Old May 29, 2014 | 06:26 PM
  #37
2014 BMW M235i
I said it sounds quite a bit like the muffler delete not quiet like the muffler delete lol
Old May 29, 2014 | 06:35 PM
  #38
Thai22's Avatar
2007 E550
Hows the drone at freeway cruising speed (65mph+)? That's my biggest issue with my current muffler delete is the drone is too much at times.
Old May 29, 2014 | 06:37 PM
  #39
2014 BMW M235i
The drone is not bad at all, you only get a little around 1800 and even then it's only a deeper note not ear-piercing sound. That's what the J-Pipe I installed on my muffler delete is for.
Old May 29, 2014 | 06:54 PM
  #40
Thai22's Avatar
2007 E550
Ya muffler delete for me is just a little too loud. As well as drone that really annoys me at times. That's why Im curious how the drone is with these vibrant resonators. I also need to put some sort of mufflers back on so I can pass visual smog inspection here in California.
Old May 29, 2014 | 09:21 PM
  #41
njmaxpayne's Avatar
2008 e550
no drone whatsoever...that's the nice part abut it,because i was worried about it and was talking to my exhaust guy and we were planning on doing the j pipe resonator if needed,but lucked out.no drone.here are some pics
Attached Thumbnails EXHAUST QUESTIONS!-image.jpeg   EXHAUST QUESTIONS!-image-1.jpeg   EXHAUST QUESTIONS!-image-4.jpeg   EXHAUST QUESTIONS!-image-5.jpeg
Old May 29, 2014 | 09:24 PM
  #42
njmaxpayne's Avatar
2008 e550
lol yeah i just read it way too fast.I usually look at all this on a small pfone screen at work so ...
Old May 29, 2014 | 09:30 PM
  #43
njmaxpayne's Avatar
2008 e550
and BTW about the drone,every car is different,a lot of things can contribute to the level of drone,things like,milage,built..etc..for example, i had a borla axlebacks on my mustang and they didn't drone much,on my friends car,same exact car a year older...drones like crazy...lol
Old May 30, 2014 | 02:24 PM
  #44
Thai22's Avatar
2007 E550
I like the sound you put together there. Especially if there isn't drone inside the cabin I may copying you.
Old May 30, 2014 | 03:49 PM
  #45
Honcho's Avatar
'03 SL55 AMG | 2021 AMG GLE 63s Coupe
I'm beginning to wonder if spending time on this forum will save me more, or cost me more. I had never really considered doing anything to something that's not broke (okay.... I could have lived with the little crack in the grille instead of getting the new one ;-), but after hearing njmaxpayne's car, I have a major urge to have someone record my car as I drive around an empty parking lot.
Old May 30, 2014 | 10:24 PM
  #46
AllCounty E55's Avatar
2003 e55 AMG
Amgafalterbach......so should I not do an x-pipe? And if I should do an x-pipe should I put in in place where the secondary cats were or further back??? I've been up in the air about this bc people say don't confuse Benz with regular v8 engines bla bla bla...I would think they operate under the same basic principles even though the are not the same.
Old May 30, 2014 | 11:04 PM
  #47
2014 BMW M235i
Usually an X-Pipe is done at the resonators, I don't see any issue doing it on an E55 versus a naturally aspirated E500 or newer E63/E550. I know several people that have done it on the M113 engine with no problem.
Old Jun 1, 2014 | 08:42 AM
  #48
Honcho's Avatar
Slight Diversion
SQUIRREL!
This is the sound I'd like please and thank you:
http://www.mercedes-amg.com/webspeci...ion_article03/
Old Jun 2, 2014 | 01:40 AM
  #49
njmaxpayne's Avatar
2008 e550
the stock resonator is originaly a H-pipe inside wraped in metal body which is full with noise/smoke absorbing glass cotton like insulation....my exhaust guy (who does exhaust work for few of the biggest speed shops in jersey imports,and US muscle) said that i could've use straight pipes and result sound/flow would've been exactly the same.engins are the same as any V8,it's just different cam's,timing,pistons tune...etc,and more electronics.so my pOint is that if u replace that resonator u pretty much replacing quieted down H-pipe with a naked X-pipe...so no need to take of secondary cats...IMO.after what i did if i took of the cats car would've sound like too loud.just x pipe and resonators will do.theres plenty of options out there..to narrow it down as far as loudnes,the LONGER the mufgler the quieter...width does not make as much difference about sound quality as lenght.width also play role too but for example a 6" round resonator will sound louder if it's 12" long and quieter if it's 16-18" long..
Old Jun 2, 2014 | 01:52 AM
  #50
njmaxpayne's Avatar
2008 e550
do u have the same car?E550?and trust me not a parking lot but a tunnel is where you can hear the angry roar of the exhaust gods LOL
