E-Class (W211) 2003-2009
Run Flats on W211
Old May 1, 2014 | 03:18 AM
62bassman's Avatar
18 GLC300 4M
Run Flats on W211
My 06 E350 has 98K and due for new rubber. I'm tempted by the Pilot AS ZF run flats. Does anyone have experience with using run flat ties in general as replacements ? I live in the northeast where bad roads are the norm and stopping to change a tire can be dangerous.
Old May 1, 2014 | 09:18 AM
vettdvr's Avatar
03 E500 and Corvette
It is dangerous to run run flats w/o a TPS. W/O TPS if you have a flat you would not know it by looking, continue driving and then the tire would eventually fail. If you put a TPS on your car then it would be ok. I run Michelin's Run Flats on my Corvette, but it does have a TPS factory system.
Old May 1, 2014 | 09:56 PM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
Those are ZP = zero pressure = runflat. I had pilot sport 2 ZP on my BMW and "normal" pilot sport 2 on my Benz both staggard 18". I gave my opinion earlier today
Originally Posted by rediesel
The only benefit to runflats is that auto-manufacturers get to design a car without a spare or the space to put a spare. Since you have a spare there isn't much benefit for you (doubt you're trying to increase trunk volume by removing the spare.)
Run-flat tires cost more, get less MPG, less grip, wear faster, rider harder etc. I had RFT on my BMW first OE Bridgestone - lasted 7500 miles, then Michelin PS2 (I also had the non-RFT on my Benz and liked, but hated in RFT on the BMW). So happy when the RFT-PS2 wore out after 13k miles so I could get some non RFT.
Old May 2, 2014 | 11:16 PM
AMGAffalterbach's Avatar
2014 BMW M235i
Not worth the extra cost in my opinion. I would go with a regular set of Michelin Pilot A/S 3s or for summers Michelin Pilot Super Sports.
Old May 3, 2014 | 10:10 PM
62bassman's Avatar
18 GLC300 4M
Got the AS3 tires. They are solid and a smooth ride. Thanks for the good advice.
