Fuel Smell Inside Cabin
My questions are, has the MBUSA issued an recall for this issue? If not, what exactly needs to be replaced and how much will it cost? I can barely stand the smell any more and hate to even fill up my gas.
Any help is greatly appreciated!!
To be on the conservative side, start by removing the rear seat bench and take off the round cover that covers the sending unit. If you see gas on the unit, it could be the unit is leaking and needs to be changed. If gasoline is only on bottom of unit, it could be a bad seal which you could replace yourself if you're a handy person.
replaced fuel sending unit/pump and few other minor stuffs...
is ur car out of warranty?
How much did you guys paid to have it replaced? Yeah, my car is way out of warranty. I currently have 115k miles on it.
Frist, remove the bottom of the back seat, there are two tabs under the cushion that will allow you to remove it. You will then need to remove the access pannel that covers the sending unit, behind the driver's seat, which is round and has about 8 or so sheet metal screws in it, they're about 1/4 or 5/16 in size.
If you see gas puddling up on top of the sending unit, mine had about 3 cups worth, get it out of there...I used a shopvac, because there was too much to soak up with rags. Once it is dried up, see if you can tell where it's leaking from. If it's coming up from the bottom, it's more than likely the seals, if it's leading from up and behind (towards the back of the car) into the trough that the sending unit sits in, it's probably a cracked fuel tank.
If MB USA doesn't cover the cost of the fuel tank, like they did in my case, you'll end up spending $3K to fix this.
If your car is a PZEV, then dealer has to cover it under warranty.
Then I saw this:
Since it appears that no one mentioned it is a bad idea to suck fuel into a closed container, while mixing it very well with air, and topping off with a brush type AC motor; Maybe knowing not to do so is a special skill?
Then I saw this:
And thought, maybe I am wrong.
There is so much wrong with your comments about shopvac'ing up gas I don't even know where to begin. Maybe it's just best to ignore your comments for those who read that. Guess what? I still have all of my fingers, I'm not missing any eyebrows and my shopvac didn't blow up like a pressure cooker bomb
. HOW COULD THAT BE? I must have defied physics and chemistry in the alternate universe you live in. Before you give advice on a subject you might want to know something about it...just a suggestion.Anyways, the point of the subject, if you can determine where the leak is, roughly, coming from you can figure out if it's a cracked gas tank or if it is simply a fuel sending unit seal.
http://www.ford-trucks.com/forums/48...e-liquids.html
WARNING – TO REDUCE THE RISK OF FIRE, ELECTRIC
SHOCK OR INJURY:
1. Do not leave appliance when plugged in. Unplug from outlet when not in use and before servicing. Connect to a properly grounded outlet only. See Grounding Instructions.
2. Do not expose to rain – store indoors.
3. Do not allow to be used as a toy. Close attention is necessary when used by or near children.
4. Use only as described in this manual. Use only Manufacturer’s recommended attachments.
5. Do not use with damaged cord or plug. If appliance is not working as it should, has been dropped, damaged, left outdoors or dropped into water, contact Shop-Vac Corporation for assistance.
6. Do Not: pull or carry by cord, use cord as a handle, close a door on cord or pull cord around sharp edges or corners. Do not run appliance over cord. Keep cord away from heated surfaces.
7. Do not unplug by pulling on cord. To unplug, grasp the plug; not the cord.
8. Do not handle plug or appliance with wet hands.
9. Do not put any object into openings. Do not use with any openings blocked; keep free of dust, lint, hair and anything that may reduce air flow.
10. Keep hair, loose clothing, fingers and all parts of body away from openings and moving parts.
11. Do not pick up anything that is burning or smoking, such as cigarettes, matches or hot ashes.
12. Do not use without dust bag and/or filters in place.
13. Turn off all controls before unplugging.
14. Use extra care when cleaning on stairs.
15. Do not use to pick up flammable or combustible liquids such as gasoline or use in areas where they may be present.
16. Do not use your cleaner as a sprayer of flammable liquids such as oil base paints, lacquers, household cleaners, etc.
17. Do not vacuum toxic, carcinogenic, combustible or other hazardous materials such as asbestos, arsenic, barium, beryllium, lead, pesticides or other health endangering materials.
Specially designed units are available for these purposes.
18. Do not pick up soot, cement, plaster or drywall dust without cartridge filter and collection filter bag in place. These are very fine particles that may pass through the foam and affect the performance of the motor or be exhausted back into the air. Additional collection filter bags
are available.
19. Do not leave the cord lying on the floor once you have finished the cleaning job. It can become a tripping hazard.
20. Use special care when emptying heavily loaded tanks.
21. To avoid spontaneous combustion, empty tank after each use.
22. The operation of a utility vac can result in foreign objects being blown into eyes, which can result in eye damage. Alwayss wear safety goggles when operating vacuum.
23. STAY ALERT. Watch what you are doing and use common sense. Do not use vacuum cleaner when you are tired, distracted or under the influence of drugs, alcohol or medication causing diminished control.
24. WARNING! Do NOT use this vacuum cleaner to vacuum lead paint debris because this may disperse fine lead particles into the air. This vacuum cleaner is not intended for use under EPA Regulation 40 CFR Part 745 for lead paint material cleanup.
Thanks for sharing !!
