Easy-Exit Feature... seat not moving
just got my new E 3 days ago. Overall a great car but...
I activated the key dependant feature and set Easy-Exit to wheel & seat. It worked a few times but on Sunday when I pulled the key the seat moved back a little bit, then forward and stopped there. I started the car again and pressed Memory 1 until the seat was back in my position. I then pulled the key again - wheel went back, seat didn't move at all.
I set everything to default, set it up again but... since Sunday my seat isn't moving back!
Anyone has an idea on how to reset the seat or whatsoever?
Michael
try your other key or try turning off key dependent feature. if that doesn't work, i would go to the dealer...
sometimes my seat doesn't come all they way back into position, but it works most of the time. good luck.
Let us know if you find a solution.
thanks for the suggestion with the threshold. But I think I am not that tall so my seat is not all the way back.
I will bring the car to a local dealer on Thursday. It also pulls right and one fan in the drivers ventilated seat is making a terrible noise. I hope they can fix everything.
Hi,
) and it made the problem worse...my steering is all over the place now and i wish i would've just left it alone. anyway, they're going to look at it again, but you never know with those service guys...
by the way, be careful with the pulling (alignment) problem...they just applied some fix to mine (and still charged me for an alignment
They also don't cover seats and floor and touch the interiour with their oily hands...
Since all the problems aren't that bad - I will not give them a chance to make it worse. When I'm back in Germany I will have it checked there.
Turns out, a wire was not hooked up, so there is no way it ever worked after the tech worked on it, and he actually didn't check it. They just changed the part, screwed it back together and said "I'm done". The SA acknowledged this and was apologetic, but this is unexcusable service.
And everytime you take it in it is a multi-day affair, not once have they given the car back the same day. I can tolerate the car having problems, even my Honda does, but I take it in for service, and by the end of the day, I have a working car again, no issues.
Frankly speaking I'm finding that service is the biggest quality problem that MB has...they need to get all these dealer service centers whipped in shape. ... And everytime you take it in it is a multi-day affair, not once have they given the car back the same day. I can tolerate the car having problems, even my Honda does, but I take it in for service, and by the end of the day, I have a working car again, no issues.
Concerning car service I don't trust anybody unless I can wait for the car and watch the mechanic what he's doing. I learned my lesson.
There is a threshold position beyond which the seat will not move back automatically. If your seat is too far back (behind the threshold position), the seat will not move back automatically to the exit position when you remove the key. You either need to move the seat forward a bit for the easy exit feature to work OR the service people say that they can reprogram the car so that the threshold position is farther back.
I had the same questions a year ago with mine. After some "reasearch" the SA advised me that is is suppose to work that way to prevent a person that sits in the back seat behind the driver from getting their legs crushed, hince, only moving back to a limit.
The threshold settings seem to be different on different cars. The threshold on my replacement E500 was much further forward than on my pre-nav car.
They can and will change the threshold if you want it.
I believe that there must be a threshod position, however - I think something is wrong with my seat.
I moved it all the way forward so my knees were behind my ears. Then I pressed M and 1 to program this position. I pressed "2" and everything started moving to another position. Pressed "1" again - seat moved all the way forward as programmed. Then I pulled the key (and believe me, there was a lot of legroom at this moment) and only the wheel moved back, but the seat remained where it was.
I checked the system - it was set to "wheel and seat" + "key dependant". So this feature obviuosly doesn't work. But I just set it to "wheel only" since for me it is not that important.
