E-Class (W211) 2003-2009
Humming noise when decelerating
Old Apr 10, 2015 | 06:37 PM
Hotsauce55's Avatar
2005 E55
Humming noise when off/on throttle
I can clearly hear the difference between just barely having my foot on gas (no noise) & when I take foot off a humming sound starts. Most noticeable about 50 to 70mph. It sounds like its coming from trans tunnel. Any thoughts?
Old Apr 10, 2015 | 11:06 PM
Blitz2639's Avatar
2008 E350, 2010 GL550
Is it just a humming noise or do you feel vibration? Possible collapsed trans mount?
Old Apr 11, 2015 | 06:04 AM
Hotsauce55's Avatar
2005 E55
The decel noise is quite loud and maybe accompanied by just a little bit of vibration. Mostly noise
Old Apr 15, 2015 | 10:00 AM
Hotsauce55's Avatar
2005 E55
Bump - Anyone experience this at all?
Thoughts are trans, center bearing or maybe flex disc?
Old Apr 22, 2015 | 07:58 AM
Hotsauce55's Avatar
2005 E55
Further listening suggests:
Noise when accelerating (humming)
Noise when decelerating (louder humming)
No Noise when "just" on the gas a bit
No Noise in neutral while coasting
Old Apr 23, 2015 | 09:45 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
CENTER SUPPORT DRIVERSHAFT BEARING PROBABLY HAS EXCESSIVE PLAY. WHAT MILEAGE DO YOU HAVE ON YOUR VEHICLE? AND WHAT MAKE AND MODEL.........
Old May 26, 2015 | 02:39 AM
socal3's Avatar
2007 E350
Any updates on your issue?
Old May 26, 2015 | 06:06 AM
Hotsauce55's Avatar
2005 E55
Nobody is willing to tear into the differential but they all believe it is definitely gear noise ie. Crown/pinion gear. I am trying to source a used e55 complete pumpkin to be installed.
It is not the csb unfortunately
Old May 29, 2015 | 12:57 AM
bflaig79's Avatar
2003 e500
I have an '03 E500 and I get that same humming (higher pitched almost like a whistle) sound when I am between 70-75 mph. I slowly let off the gas and once I let off a few degrees, the humming goes away.
I was also curious as to what would be causing the sound.
Old May 29, 2015 | 10:55 AM
cmriv's Avatar
Is this a humming or howling noise? There is a difference thats why i am asking. If its howling, probably your rear diff, humming i would like to think is a wheel bearing. However if you have those bull***** AS3's on your car they could as well be producing some noise....
Old May 29, 2015 | 01:16 PM
Hotsauce55's Avatar
2005 E55
Typically a wheel bearing will get worse with speed & will obviously become louder when loaded up more ie. shifting weight from one side of the car to the other. Don't discount what crmiv said as well, I am amazed at how noisy some tires can be. With that said, I find Michelin's to be one of the quietest brands.
If you cruise at 75mph & throw car into neutral does the noise go away? If noise, goes away then try increasing RPM to that 2,000-2,500 & see if noise comes back. Post up results
Old May 29, 2015 | 08:12 PM
cmriv's Avatar
updated as3's
The new updated as3's are suppose to be legit. The old style ones are garbage imo but im picky when it comes to tires.
