E-Class (W211) 2003-2009
E 500 AIR SUSPENSION FILTER HOSES NEED HELP
Old Apr 26, 2015 | 02:53 PM
S430LUCKDRAGON's Avatar
2003 S 500 4 MATIC , 2001 S 430 , 2003 ML 500
My 05 E 500 was giving me a message to visit workshop
I took a peek at the comressor and the tube was broken that connects to the filter it was broken on both sides , but i can not find where the other end of the tube that comes off of the filter connects to can some one help me with this ?
Any pictures or diagrams of the filter and where it goes ??????????
Old Apr 27, 2015 | 11:11 AM
DanG2's Avatar
04 E500
Don't have a picture, but I think this might help to answer your question: http://www.benzworld.org/forums/w211...-airmatic.html
If you're getting a message to visit the workshop, the broken hose may have allowed enough dirt get into the compressor to damage it, and you may need to repair or replace it. See http://www.benzworld.org/forums/w220...ce-filter.html
Old Apr 27, 2015 | 02:57 PM
Ok wow i really appriciate that , its just soo strange because there was a small clamp that fell off of the other end of the hose any ways compressor probably is filled with dirt and oil and sounds like its shorting out now we know why lol
Old Apr 28, 2015 | 05:28 PM
sthoms's Avatar
2004 AMG E55, 2011 Ram 2500 6.7L
I have done both hoses and filter. Will see if I had any pictures. (or found any)
Otherwise I can take some.
My hoses were cracked AFTER the filter, so the pump was shot as DanG2 warns.
I replaced the pump, hose to the filter, the filter (was visibly dirty @ 120k) and the hose to the air cleaner assembly.
Old Apr 30, 2015 | 12:50 AM
Ok thanks if you find pics that would be cool but the hose on the upper part of the filter just exposed is that correct ?
Old Apr 30, 2015 | 11:46 AM
DanG2's Avatar
04 E500
The hose on the upper part of the filter (the filter inlet) goes to atmosphere just like the inlet to the filter of pretty much any air compressor goes to atmosphere. EPC lists the hose as,"FROM CROSSMEMBER TO AIR FILTER," so I expect that if you look around on the crossmember you should be able to find a bracket that the hose tucks into, as shown in the following screenshot:
Old Apr 30, 2015 | 11:08 PM
DanG2 your the man i knew some body would know this , now i know i am not crazy there was a small clamp on the end of the hose so i know that it goes some where i will be doing some more work on saterday cleaning the comressor and putting the hose in correctly i will report progess thanks alot
Old Mar 9, 2016 | 08:44 PM
llcelebrity's Avatar
1993 Mercedes 300SE
did you ever find out if the other end clamped to anything
Did you ever find out if the other end the open end was clamped to anything
Old Mar 28, 2019 | 08:23 AM
Justory's Avatar
2003 Mercedes e500
Part numbers
[QUOTE=DanG2;6414020]Don't have a picture, but I think this might help to answer your question: http://www.benzworld.org/forums/w211...-airmatic.html
If you're getting a message to visit the workshop, the broken hose may have allowed enough dirt get into the compressor to damage it, and you may need to repair or replace it. See http://www.benzworld.org/forums/w220...ce-filter.html[/.
Do do you guys have the parts number for everything I would need to complete this job or could you point me in the right direction?
