Take 2 times to go when i press gas pedal
When i pres gas pedal (mostly when im slow from gear 1 to 2 ) it takes two times to change or after changin gear i dont understand it well. Firstly it change the gear but does not go down just take a empty space full of gas then go normaly. I can post video if u dont undersand . Sorry for my english. Thnx
The ECU looks at many factors to decide when it should shift down, or just open the throttles more. Try varying your driving style a little and see if it feels smoother, these cars are designed to be driven with very small throttle inputs compared to many other cars, and are somewhat hesitant to aggressively take off unless you floor the throttle.
Also, if you step down right as the transmission is shifting to the next gear, it makes the delay of kickdown even more noticeable. The torque management after a shift has the car feeling even less responsive, then it has to go back into that mode, change gears back down, come out of torque management, then open the throttle. It feels like a big delay if you're expecting instant response like an older cable throttle car.
