E-Class (W211) 2003-2009
After market Android 4.4.4 Quad Core complete install. Vids and Pics and txt
Old Feb 11, 2016 | 08:36 AM
  #251
JoeNobody's Avatar
Mercedes
The bypass cable is still desired, because it has a short harness you can cut up to connect amp to speakers.
Old Feb 11, 2016 | 04:08 PM
  #252
Dnasty's Avatar
2010 e550 coupe
Does the bypass cable not include all the factory speaker wires?.. I thought i read that I still would need to tap into the shelf speakers. Trying to figure out how many channel amp I would need if i just want to run direct cable is the stock amp a 6 channel amp?
Old Feb 11, 2016 | 06:19 PM
  #253
garagequeen's Avatar
car
All mine work other then the one right in the middle in the rear head rest area.
Old Feb 11, 2016 | 07:34 PM
  #254
Kokopelli's Avatar
2003 E55
I am running a 5 channel amp. 1 for each door speaker and then 1 for the sub.
This is the amp I got.
Amazon.com : PIONEER GM-D9605 GM Digital Series Class D Amp (5-Channel Bridgeable, 2, 000 Watts max, With Wired Bass Boost Remote) : Electronics Amazon.com : PIONEER GM-D9605 GM Digital Series Class D Amp (5-Channel Bridgeable, 2, 000 Watts max, With Wired Bass Boost Remote) : Electronics
For 200 it sounds really good. Way more power than the stock set up.
Now if I could only figure out how to get to the sd cards without breaking the covers. Kind of sucks that it didn't come with any manuals.
Old Feb 11, 2016 | 08:10 PM
  #255
Dnasty's Avatar
2010 e550 coupe
This is the amp I got. Amazon.com : PIONEER GM-D9605 GM Digital Series Class D Amp (5-Channel Bridgeable, 2, 000 Watts max, With Wired Bass Boost Remote) : Electronics
That was literally what I was about to order but aren't there the two rack speakers in the back seat and the front center speaker as well or are they included in the same wire as some of the other speakers? Also did you hook that up via straight rca's out the head unit?
Old Feb 11, 2016 | 08:12 PM
  #256
car
Give me 30 mins or right after dinner and I'll post up mine. I got it all done, just need to put everything in.
Old Feb 11, 2016 | 09:47 PM
  #257
Kokopelli's Avatar
2003 E55
I didn't wire up the center channel or the small rear deck speakers. I can still switch things up easily later if I want to try it. I'll just wire the left speakers to one channel the rights to another, use 3 and 4 to drive the center and rears and the last for the sub. The amp has high and low pass filters so you can set it up so you don't overpower the smaller speakers. Probably take all of 10 minutes to switch it up.
It sounds really good as it is right now.
Old Feb 11, 2016 | 10:27 PM
  #258
Dnasty's Avatar
2010 e550 coupe
Oh so even without those speakers the sound is better? Also did you run rcas out the head unit to the amp or did you just use the 6m harness.
Old Feb 11, 2016 | 10:36 PM
  #259
car
Ok so I messed up and ran the antenna wire backwards, so I won't need that cord I ordered.
So the only thing I ordered was the radio and 6meter cable.
What doesn't work, the sub in the rear seat head rest place.
Sounds like stock but with no bass.
So ran RCA cables and a AMP wire from the back of the radio (the plug kit came with the radio) to the amp in the trunk.
Power wire and amp fuse ran from battery to amp.
ground wire ran from ground point on the body to the amp.
Boom got a sub working. Will be making a custom box to fix where I have this one, just wanted to make sure it worked. This amp and sub were out of my old truck.
Ran all the wires down the driverside( US driver side)
GPS, radio, bluetooth, mic all work fine.
Well I can't upload photos from my computer now. I'll try when I go into the house.
Old Feb 11, 2016 | 10:37 PM
  #260
Kokopelli's Avatar
2003 E55
I used the 6m harness. The amp has high level import support and I use all four channels from the headunit as inputs. I would have had to run two additional pair of rca cables along with the 6m cable to maintain fader and balance from the headunit. Would have been a little tight fitting the additional wires under the door sills.
Old Feb 12, 2016 | 12:38 AM
  #261
Dnasty's Avatar
2010 e550 coupe
Yea i am trying to figure out the best way to wire my setup as I already have 2 12's in the trunk and a 1600 watt amp tapped into the sub wire in the back. I was thinking of going all rcas to the new amp for the car speakers (also removing the line in converter for my 2 12's and running the subcable from the headunit to that as well.) but is there additional stuff in that harness that I need? I see a bunch of stuff in there I don't really know what it is like canbus and possibly remote wire gps wire? Also you said you would use all the right speakers on one chanael and left speakers on anohter channel wouldn't that significantly decrease the sound output if you configure it like that? Was thinking of mabye something like this as it has enough channels for everything not sure of the brand they probably over rate their specs but I wouldn't have to sacrifice any channels
Amazon.com: Lanzar HTG888 Heritage Series 5000 Watt 8-Channel Mosfet Amplifier: Electronics Amazon.com: Lanzar HTG888 Heritage Series 5000 Watt 8-Channel Mosfet Amplifier: Electronics
......... or could a six channel amp be used and the front center and shelf speaker all be put on one channel?
Old Feb 12, 2016 | 06:20 AM
  #262
Kokopelli's Avatar
2003 E55
I don't have it set that way. I said it would be an option to get the center and rear deck speakers to work but I am happy the way it is.
Old Feb 12, 2016 | 08:20 AM
  #263
Dnasty's Avatar
2010 e550 coupe
Yea I was wondering if the sound quality would be diminished in that setup, I know you said you where running only the four door speakers and the woofer. Is that amp small enough to place where you have your old mercedes amp?
Old Feb 12, 2016 | 08:29 AM
  #264
Kokopelli's Avatar
2003 E55
It's too big to fit where the stock one was. I have it mounted where Xpresion has his mounted. Had to ditch the spare tire compartment liner. Having it there provides easier access to tweaking the set up. Would be a real pain to have to remove everything to adjust the gain or filters.
Old Feb 12, 2016 | 10:44 AM
  #265
tubaprde's Avatar
E55, past: SL55, 560SEL
Bluetooth works ok for you? have you tired making phone calls? any echo/static on the other end?
Old Feb 12, 2016 | 05:13 PM
  #266
Kokopelli's Avatar
2003 E55
My bluetooth is working fine using the mic they provided. I mounted it at the base of the rearview mirror.
Old Feb 12, 2016 | 05:39 PM
  #267
Dnasty's Avatar
2010 e550 coupe
Just curious but which head unit do you have is it the same as the op? There are tons of these quadcore rk3188 headunits on ali express I am assuming they are all essentially the same thing with different desktop orientations in their ad?
Old Feb 12, 2016 | 05:52 PM
  #268
Kokopelli's Avatar
2003 E55
I used the link in the op's post to order.
Old Feb 12, 2016 | 07:02 PM
  #269
tubaprde's Avatar
Are you running the original os?
This might mean that my unit f'd.... I bought the unit, exact same as op, from the same store....
Old Feb 12, 2016 | 07:15 PM
  #270
Dnasty's Avatar
2010 e550 coupe
Are you using the built in mic or did you use the extension that lets you mount a mic?
Old Feb 13, 2016 | 11:11 AM
  #271
tubaprde's Avatar
I tried four different Mic's including the OEM Mic and Mic that's built into the unit, and two aftermarket Mics that use an extension. They al produced the exact same result.
Old Feb 13, 2016 | 01:00 PM
  #272
Kokopelli's Avatar
2003 E55
Stock OS. Everything is working fine for me except when I use music streaming apps. The steering wheel buttons for going forward and back don't work and the gauge cluster says AUDIO OFF. The volume still works so I'm still happy. Anything is better than the Audio50.
Old Feb 13, 2016 | 06:02 PM
  #273
Dnasty's Avatar
2010 e550 coupe
I have a 1600 watt mono amp in the spare area now that powered my two 12s so I was kind of hoping I'd be able to fit this pioneer where the old factory amp was. Looks like I'm gonna have to remap this out a bit.
Old Feb 17, 2016 | 03:07 AM
  #274
Dnasty's Avatar
2010 e550 coupe
Do you think it would be possible to run the shelf speakers and the front center speaker all to the subwoofer channel output on the amp? Or are those speakers even worth a damn.. I think I might actually remove the sub from the car all together as I have 2 12's in the trunk and believe that will actually allow more bass to enter the car.
Old Feb 21, 2016 | 10:01 AM
  #275
gazosnic's Avatar
e46 m3, w211 e55
impact on center display...
When you install this what happens to the integration of the cluster display? Right now it shows the streets when nav is on, radio station, etc. If putting in this unit does this all go away? Are there any errors that come up?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
