E-Class (W211) 2003-2009
2006 E350 4matic manifold intake
Old Sep 27, 2015 | 12:17 PM
julianjviso's Avatar
e 350
Just had my E350 manifold intake replaced. Dealer wanted $1,200 for the part plus $600 labor. Found original part for $600 in @europarts.com
Dealer agreed to install part for $350 if I could buy the original part cheaper.
Is the manifold intake replacement an issue for E350s with 145,000 miles??
Is there a market place for used manifold intakes? My service guy said there was a market for used manifold intakes. Where should I go...
Old Sep 27, 2015 | 01:13 PM
OnlyGerman's Avatar
Too many german broads
Had mine replaced at 107k
Old Sep 28, 2015 | 09:56 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
Yes these I/M tumble flaps break, cause would be dirty engine bay, debris, and things of that sort. Those dealership prices sound correct to me. I would purchase the part from a different vendor and have A dealership install it. You'll need new gaskets, hardware, and injector o-rings.
BTW this is A DIY job. it seems challenging but it really isn't!
Old Feb 14, 2016 | 07:29 PM
tombenz's Avatar
w211
Just replaced my intake manifold on 2006 E350 w 150k miles. It is a DYI job.
Old Feb 15, 2016 | 04:07 PM
sskamboj's Avatar
09 W211 E-350 4Matic w/ Sport and AMG Packages
I just had mine replaced under my extended warranty at 71k miles. I guess the runner on the intake manifolds is an issue on this car like it was on my VW GTI. Not nearly as common though.
Old Feb 17, 2016 | 03:52 PM
Blitz2639's Avatar
2008 E350, 2010 GL550
You can also search for 272 intake manifold rebuild and can buy the linkage that's actually the usual cause of failure. Less money than a whole manifold and is still DYI.
Old Feb 18, 2016 | 02:14 PM
cmriv's Avatar
He is right. You can buy the linkage, however there is a guided test when linkage breaks. Vacuum test to be exact, applied vacuum. So in theory you can repair the linkage, yes, but you wont know if something internally is faulty unless you measure the voltage when vacuum is applied.... Is how i remember i think.
Linkage is alternative imo if you know for sure something internally isn't faulty as well.
Old Feb 23, 2016 | 09:49 PM
62bassman's Avatar
18 GLC300 4M
What is the indication of failure, and are there any videos of dyi ?
Old Feb 24, 2016 | 07:01 AM
Blitz2639's Avatar
Just a check engine light with tumble flap codes. Someone else would have to chime in about videos. I've never checked.
Old Dec 29, 2017 | 03:13 PM
OceanView's Avatar
W212 & W210
Any updates on this?
I just got this error and wanted to see if I can save some money on a DIY.
Trying to decide if I can do just the parts or will I need to do the entire intake maniford
Old Dec 29, 2017 | 05:23 PM
cetialpha5's Avatar
I think it boils down to how long you're going to keep the car. I'd say if it's less than a year, go for those parts, probably still cost around $100 for a kit. Otherwise if you're going to keep it longer, get the manifold, they're about $466.
https://www.fcpeuro.com/products/mer...ierburg-516475
There's actually a few videos on youtube about doing the manifold.
Old Dec 30, 2017 | 12:15 AM
Russell Ormerod's Avatar
not a merc
The link that breaks is for the tumble flaps, which triggers the fault code.
The parts that break inside are for the variable length manifold.. which can damage the engine if a piece ends up through an intake valve. You could split the manifold and remove all variable length flaps completely, You will never have issues again.
Old Dec 30, 2017 | 11:30 AM
cetialpha5's Avatar
Won't that affect the performance of the car? Basically the variable length is tuned for the rpms of the engine, one set for low and another for high rpms. If you get rid of them, it will only be one and it will probably run rough at low or high rpm.
Old Dec 30, 2017 | 03:02 PM
not a merc
It may loose a bit of torque, but it will still run smooth. I have done it without any issues.
Old Mar 27, 2018 | 07:24 PM
vee12's Avatar
W221 S65, W140 S600, W210 E430, W126 300SD
I see the K&N CIA systems for Camaros, Mustangs, trucks, etc in JEGS catalogs (and others)...using a poly/plastic/silicone runner from the throttle body to the filter. It would seem that at least one (or maybe a couple) of these applications might have a size and/or shape RUNNER that would fit onto our TTV12s from the turbo to the radiator support. Has anyone done any research in this area? Sure would be nice to have a "pre-fabbed" factory looking plastic runner without all the hose clamps and BS. I wish I could go out to the Summit Racing store here in Atlanta and pilfer through their entire CIA inventory and see if one of those damn things would fit.
Old Mar 27, 2018 | 07:48 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
The W211 E Class section, where we talk about our twin turbo V12s.
