Change My Own Oil? What Kind?
Subscribe
Apr 9, 2016 | 07:58 PM
Thinking about getting a vac system and changing my own oil from top.
What oil is everyone using now for diesels?
Mine is a 2009 E-320 Bluetec with 41k
I see a Mobil 1 5w-40 but for diesel trucks?
The ESP I think is 5w-30?
Thx!
Reply 0
Apr 9, 2016 | 08:06 PM
It depends on the climate where you're at, and the mileage on the engine. Here in SoCal, I use the Mobil Synthetic 0w-40
Reply 0
Apr 9, 2016 | 08:17 PM
IN NC Mountains with 4 seasons - nothing too harsh at all. Garaged all the time (heated) - and have 41k on it now.
Reply 0
Apr 9, 2016 | 08:26 PM
Here's a thread I found for you: https://mbworld.org/forums/e-class-w...il-change.html
Reply 0
Apr 10, 2016 | 04:01 PM
https://bevo.mercedes-benz.com/bevolisten/229.52_en.html
It has to be 229.52 certified
Reply 0
Apr 10, 2016 | 06:47 PM
I'd recommend Mobil1 5W-40 or 0W-40, European Car Formula. Dealers, from what I understand, basically use both, or - rather - switched from using 0W-40 to 5W-40 due to some bleed down issues in their AMG engines. You can't really go wrong with either, but as a previous poster said, it's best to tailor it to climate.
Reply 0
Apr 10, 2016 | 07:57 PM
Mobil1 European is not 229.52 certified. The European oil is good for vehicles without the DSP (?) system. I believe that the European oil is rated 229.51. This is what I use in my 2006 cdi.
Mike T.
Reply 0
Apr 10, 2016 | 10:35 PM
Didn't read OPs post and subsequent replies carefully enough, I meant for gasoline engines, my apologies. You're right that is not DPF safe.
Reply 0
Explore
Apr 15, 2016 | 08:56 AM
M1 5W/40 used the year around. But here in Cincinnati, our winters only have a few below freezing days and our beloved E350 4Matic is always garaged over night.
Reply 0
Apr 15, 2016 | 12:26 PM
Here's the list of approved oils:
http://bevo.mercedes-benz.com/bevolisten/229.52_en.html
Both 5W30 and 0W30 are fine for your climate.
Reply 0
Subscribe
Currently Active Users (1)
