Alternator not charging after replacement
-First I replaced the voltage regulator but still got the occasional warning.
-I then replaced the main battery because I wasn't sure when the previous owner had last replaced it and it didn't have a date on it.
-Then the system stopped charging and I got the red battery warning so I replaced the entire alternator with a DB Electric model ABO0337 from Amazon (new not reman).
-The car was running and charging but the voltage never got above 13.8. I was expecting to see it above 14.
-All of the sudden last night after performing great all day (and my wife was driving it so the stereo wasn't on!) I got the red battery warning. I checked voltage and it's not charging again. Voltage reads at 11.7 and slowly dropping if I turn things on.
-I figured it probably wasn't the problem but I went ahead and replaced aux battery that was 2 years old (I live in AZ so that's a long time).
So now I have two new batteries and a new alternator. The system is still not charging. The belt looks fine and I don't hear any slipping.
Could it really be another bad alternator after only a couple weeks? Is there something else upstream that could be causing the alternator to fail?
I'm not sure what else to check. Any advice is greatly appreciated!
You measure that alternator is not giving charging voltage, yet you replaced the battery?
Those cars have crazy electronics and I had the "convenience" message for long time (vacations) when the car voltage was still about 14V. Turned out not torqued battery clamp bolt.
13.8V is normal charging voltage when everything is stabilized. Can go to 14V when you start the car and battery is discharged.
Anyway, where do you measure the voltage? Car display often shows 0.5V less than actual battery measurement.
Cheap aftermarket alternators are often garbage, I replace a lot of them at work that fail within a year or are bad right out of the box. I'd suggest a quality rebuild over a cheap new one, or a new OEM as the best solution but I know they are NOT cheap.
I measured it by the dash display and with a volt meter on both batteries.
They are based in Tennessee, and I bought it on Amazon for $175. The company had good reviews and were recommended on other forums...but I still had that thought in the back of my head that it was a gamble.
Even if it wasn't as good I hoped it would last more than a few weeks. I should have just paid for a reman Bosch I guess, then I could at least rule that out.
Mike T.
Sure worth trying if it takes few minutes, but out of curiosity I punch my car into db site.
The alternator that popped up will never fit my car.
If there some way to de-activate this entirely in the e class?
We have seen all sorts of issues similar to yours with people using cheap aftermarket batteries and alternators. I guarantee a new OEM battery will last you way longer than 2 years. Typical life here is about 5-6 years+
Mine is MB C200 W204 Year 2012 (engine M271)
I turned on the fancy feature to monitor the Voltage and Current on the dashboard.
All the lights, AC, radio are turned off.
- Initial battery voltage: 12.3V (I use new AMARON battery in July 2020)
- A while after starting the engine, the voltage drop to 11.5 V ( I think this is normal)
- Afterward, the voltage increase and reach 14.1V (current above 0)
- I start to turn on the radio, AC, and finally lights, the voltage still showing 13.6-13.9 V (current above zero)
- Shift the automatic tranmission lever from P to R, the voltage drop to 13 V (current drop to below zero around -2A)
- Shift again the automatic transmission lever from R to N, the voltage increase to 13.6-13.9V (the current back above zero)
- Shift again the automatic transmission lever from N to D, the voltage drop again to 12.3-12.4V (the current drop and fluctuate between +1 to -20 A)
After driving the car for about five minutes, the red engine warning light flashing and later car stall
After turn off everything, I ignite again and the engine is OK.
But the car will stall again after driving a while (like 5 minutes).
Do I need to replace the regulator for sure?
Thank you
