E-Class (W211) 2003-2009
Starts>rough idle>dies
Old Nov 29, 2016 | 09:55 PM
jrobin4776's Avatar
2003 E320
Exclamation Starts>rough idle>dies
Title says it all. Acts like its not getting fuel, but has 3/4 tank. No check engine light, no codes. 2003 E320 W211
Any help would be GREATLY appreciated! Car stuck in parking lot.
Not sure if related, but fueling car very difficult to refuel as fuel backs up and cuts off pump. I understand this is due to charcoal canister and fuel vapor being captured.
Old Dec 3, 2016 | 10:10 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W211 forum...
Old Dec 3, 2016 | 04:10 PM
EMFAudio's Avatar
2014 ML63 AMG, 2012 McLaren MP4-12C, 1999 GMC Sierra, 1994 Chevy Astro, 1990 Honda CRX
Generally speaking on cars as a whole, that's usually either factory security shutting it down because it's not sensing a key chip OR mass air flow sensor malfunction.
Have you done anything like replaced anything, or washed the engine bay or anything recently?
Old Dec 3, 2016 | 07:17 PM
joseph-aaron's Avatar
2004 e320
Mine kinda does the same but don't cut off. It kinda lunges. Not sure how to say. Find anything will let ya know. Sounds like same problem im not sure
Old Dec 3, 2016 | 08:13 PM
EMFAudio's Avatar
Stopped up fuel filter will do that.
Old Dec 3, 2016 | 08:20 PM
2004 e320
Sounds right to me. Lots I don't know about this car its a 2004. I know old jeeps, firebirds this is different. Thanks!!!
Old Dec 3, 2016 | 08:31 PM
EMFAudio's Avatar
The basics are still the same, always start there.
Old Dec 19, 2016 | 11:38 PM
Toastr's Avatar
W211 - 2003
Yeah, hopefully it's the fuel filter, if not it sounds like there may be something jamming up the fuel lines beyond the filter.
After that, you'd need to check the injectors, etc. All things that would be difficult to do without it being in a shop. Did you have any luck?
Old Dec 20, 2016 | 07:30 PM
2004 e320
Don't know yet get off work everything's closed. Off Friday looking a local shop right now. Did it again today in stop and go traffic. It will run fine hit the brakes rpms go kinda crazy skips like a bad spark plug and cut off. Jerk behind me almost hit me. Put it in "N" fires back up and runs fine. Its almost everyday now it happens. Wondering what I'm paying for car lot bought it from says "HUH". If my wife was driving it and that happened she would be hit. She wouldn't know what to do. I'm thinking mines a mix of roughs trans shifting and something else. Don't know if its 2 different problems or one problem. Trying that "relearn" transmission thing found on a site in the morning. Maybe can rule out one problem. I just don't know.
Old Dec 22, 2016 | 12:56 AM
Toastr's Avatar
W211 - 2003
It's surging then stalling when you press the brakes?
Could be an electrical short somewhere, but I'd start by having them do a voltage check on your batteries/alternator if that's the case.
Old Dec 22, 2016 | 01:08 PM
EMFAudio's Avatar
On older cars I've seen bad ground from the battery to chassis or battery to motor cause those symptoms. That also means, a loose or corroded connection at the battery could cause the same.
Old Dec 22, 2016 | 07:33 PM
2004 e320
Thanks guys! This one cant figure out. Found a local shop only work on Mercedes. Maybe my problem will help others. Find out tomorrow. Thank you all for help. Your advice has helped more than can say.
Merry Christmas!!!!
