E-Class (W211) 2003-2009
Odometer showing ------
Old Feb 8, 2017 | 02:24 AM
nivram13's Avatar
E240 -2003 E55 AMG -2005
My stealer battles continue, my car was recently at the dealer for 3 weeks while they diagnosed an ESP\ABS issue which they eventually resolved.
Got the car back now the odometer is flashing showing ------ my mileage\KM reading has gone.
Dealer claims the it came in with this issue and they will need to rescan with SDS to diagnose and could be failed instrument cluster which is complete BS!
The car did not have this problem until they worked on it.
Does anyone know how I can restore my original odometer reading?
Odometer blank?
Old Feb 11, 2017 | 02:26 PM
justinp95's Avatar
E430
Ya, mine does that too. PO claimed it happened when they replaced the battery.
Old Feb 12, 2017 | 03:16 AM
nivram13's Avatar
Have you tried disconnecting and reconnecting the battery to fix it?
Old Feb 12, 2017 | 04:29 AM
swatty's Avatar
220SE Coupe, ML250, E320
You need to run a scan on the instrument cluster and reading will return
Old Feb 22, 2017 | 10:01 PM
nivram13's Avatar
That did not work, any other ideas?
Scanned the ICM no errors present.
Old Mar 12, 2017 | 12:23 AM
nivram13's Avatar
SLOVED
MB tech has left instrument cluster warning buzzer deactivated in Xentry. Fix was to re enable warning buzzer and odometer reading returned.
Old Mar 12, 2017 | 01:39 AM
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
Great you got it solved, but in truth buzzer should not affect that. I think there must been other coding options messed too, and when they re-coded KI unit, also odometer reading was solved.
Old Mar 12, 2017 | 02:21 PM
nivram13's Avatar
Interestingly as a test when the buzzer was deactivated again within the SBC test the odometer went back to ------ very strange just happy to have my odometer reading back again.
Old Jun 20, 2019 | 12:43 AM
Benzkid1224's Avatar
Mercedes e320 w211
Don't mean to sound like a noob...but what is the "Xentry" yall are talking about?
I have no clue how to get my reading back. Please help!
Old Jun 20, 2019 | 07:07 AM
nivram13's Avatar
See above for solution you'll need DAS\Xentry to fix this issue.
Old Jun 22, 2019 | 04:25 PM
1970gsx's Avatar
'06 E55
I just went through this with the E320 Wagon I bought last week. As stated above you'll need Xentry/DAS which is Mercedes diagnostics software to reset it. It took 30 seconds once in the Instrument Cluster section. Post your location and maybe someone nearby can help. I'm in S. NJ
Old Jun 23, 2019 | 12:48 PM
Autolevel61's Avatar
2009 E350
I know a guy that charges like $300 let me know
Old Jun 24, 2019 | 04:52 PM
1970gsx's Avatar
'06 E55
$300? I guess I'm the only one who help people out for nothing.
Old Jun 24, 2019 | 05:21 PM
2009 E350
If it were me I would help you out this guys expensive. Only individual I know of with star
Old Oct 17, 2019 | 12:58 PM
Buttas177's Avatar
E55
The same thing happen to me when u came back from the dealer, does anybody have access to fix this near the bronx, really don't want to go back to the dealer.
Old Nov 27, 2019 | 04:17 PM
Dave Ong's Avatar
s211
Same thing happened to my 2004 wagon when I brought it to the stealership in hoffman estate for a SBC error, anyone here from Chicagoland that are willing to help and resolve this issue? I don't want to go back to that place and spend $175 for nothing.
Old Nov 27, 2019 | 05:03 PM
nivram13's Avatar
This only fix is to hook it backup to Star and get them to exit the SBC module check correctly which they should have done anyway so why would they charge you, my stealership attempted to BS me that I needed a new instrument cluster to fix that was the last time I ever set foot in that stealership.
Old Aug 16, 2022 | 11:53 AM
malik313's Avatar
Mercedes Benz
W212 mileage is flashing and showing - - - - -
[QUOTE=1970gsx;7785480]I just went through this with the E320 Wagon I bought last week. As stated above you'll need Xentry/DAS which is Mercedes diagnostics software to reset it. It took 30 seconds once in the Instrument Cluster section. Post your location and maybe someone nearby can help. I'm in S. NJ[/QUOTE
any help
Old Aug 16, 2022 | 12:27 PM
1970gsx's Avatar
'06 E55
[QUOTE=malik313;8617357]
any help
If you are close to me I can help
Old Aug 16, 2022 | 03:27 PM
BenzNinja's Avatar
Former Vendor
why are you guys responding to posts from 2019 ?
Old Aug 16, 2022 | 04:05 PM
1970gsx's Avatar
'06 E55
Because he asked for help today, and I responded. When someone doesn't search before posting, someone will say "try the search function". So when a person uses the "search" you respond with that^? It's still a valid thread so go back to reading current stuff.
Old Aug 16, 2022 | 04:54 PM
BenzNinja's Avatar
Former Vendor
best i've seen is somebody responding to a 2009 post
just wondering
Old Nov 3, 2022 | 05:10 PM
Tiamyg's Avatar
2005 clk320
im in NJ bro my clk is having the same issues battery was just changed miles is showing ——- anyone in Nj can help me out @Tiiamyg on ig if you can DM me
Old Nov 3, 2022 | 05:11 PM
Tiamyg's Avatar
2005 clk320
whats your info iG or fB im in Nj too I need this done
any help
Old Nov 3, 2022 | 05:13 PM
Tiamyg's Avatar
2005 clk320
[QUOTE=1970gsx;8617377]
im in SOuth Jersey bro where you located ? @tiiamyg on IG if you can hmu I need help getting my odo to read miles again
