E-Class (W211) 2003-2009
Front suspension Pop - tie rods/upper BJ?
Old Mar 12, 2017 | 10:57 AM
ps2cho's Avatar
E
2008 E350 4Matic
I replaced lower arm, lower ball joint and sway bar link previously.
Its making a pop when coming off the driveway, or when the weight shifts onto the drivers side when I turn the wheel.
I'm replacing the upper control arm and ball joint either way, but now I'm considering doing the tie rods as well, because I'll have to get the car aligned and last thing I want is for the tie rods to head out soon and have to pay for another alignment.
I have 123k now. Does it make sense to do the tie rod ends as well? Or is it unlikely that tie rods will make a popping noise?
Old Mar 12, 2017 | 03:10 PM
F1Fan's Avatar
I don't think it should make a pop but it will definitely improve the steering wheel feel by making it feel tighter.
Old Mar 14, 2017 | 06:32 AM
rodneypierce's Avatar
2009 e550 4Matic
I have a horrible clunk on the passenger side. Only when going slow, entering my complex we have like a 1/4 curb, and it clunks every time over there. You can feel it in the floor board. Also will clunk if going under 15 mph and turning left. But will not do it just turning, making a right turn. It also will not clunk when turning left into my complex, but will turning right. (odd eh?)
I have replaced the following in the front:
Upper control arms/ball joints
Lower ball joints
CV shafts
Wheel bearings
Inner and outer tie rod ends
Sway bar end links.
My next step this weekend is to replace the actual sway bar bushings themselves as well as the motor mounts and transmission mount (which are shot). I plan to go to town under the car with a pry bar and see what I have movement in.
Only thing left up front is the lower control arm bushings, and the sway bar frame mount bushings. Everything else is brand new.
Old Mar 14, 2017 | 10:17 AM
ps2cho's Avatar
E
if you can find the sway bar bushings let me know because as far as I know MB forces you to buy a whole new sway bar.
Old Mar 14, 2017 | 11:51 AM
2009 e550 4Matic
https://febestparts.com/FRONT_STABIL..._KIT/BZSB-211F
Old Mar 16, 2017 | 03:18 PM
cetialpha5's Avatar
When did you do your brakes? I had a clunk also on the driver's side, went away after I did the front brake pads.
Old Mar 16, 2017 | 09:41 PM
ps2cho's Avatar
E
Originally Posted by rodneypierce
Nice!
Found on amazon so free shipping:
Amazon Amazon
Old Mar 18, 2017 | 11:13 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
Popping noise would make me think its something internal inside the rack and pinion or it could be tie rods like you said, can you duplicate noise without moving? Ball joints squeak and clunk. LCA bushings could make a popping noise but usually if those are that bad fluid would be present usually. Could you post a video?
Old Mar 19, 2017 | 02:11 PM
2009 e550 4Matic
Alright, so I didnt end up doing the sway bar frame bushings, as they were fine. I did do motor mounts and transmission mounts yesterday. As well as tightening every bolt in the front end of the car (outside of lower control arm cross member mounting points) as well as the three nuts on the top side of each strut mount. I cant say for sure what got rid of my clunk, but its now gone. Car rides SO much better with new mounts. Wow!
Old Mar 19, 2017 | 08:18 PM
nivram13's Avatar
E240 -2003 E55 AMG -2005
Lower ball joints
CV shafts
Wheel bearings
Sway bar end links.
I had a very similar issue when turning at very low speeds such as in a car park I would get a clunk and sometimes pop noise. Turned out it was the lower control arm replaced it which fixed it for a few months. However the problem returned the control I used was an aftermarket one that failed replaced again with quality lower control arm from FCP Euro fcpeuro.com no problems since.
Old Mar 20, 2017 | 05:27 PM
cmriv's Avatar
were your mounts visibly broken? if so that what the pop noise was from!
Old Mar 22, 2017 | 12:45 AM
2009 e550 4Matic
Drivers side was pretty shot. Passenger side was fine.
Old Mar 22, 2017 | 05:51 PM
cmriv's Avatar
Yeah sometimes they can be so collapsed torque causes engine to jump at times or the vehicle flexing over steep retarded made entrances. again other things could be the source as well but that does occur. The only other thing you didn't note that you have replaced is lca bushings. and of course rack and pinion. But glad you resolved issue.
I always tell people/friends that changing your engine suspension is going to make the car feel like a brand new car. Cabin vibrations drive me irate. 4matic 211 owners got it made though, them jokers (motor mounts) take about 7 minutes a side. A little bit of time and new mounts will make you fall in love all over again.
Old Mar 22, 2017 | 06:00 PM
2009 e550 4Matic
Indeed. It took me longer to jack the car up, remove the wheels and gather tools than it did to change the two mounts.
Old Mar 22, 2017 | 06:25 PM
cmriv's Avatar
Story of my life. FWIW next time just turn that steering wheel so you can sneak your hand in there!
Old Mar 24, 2017 | 10:05 PM
ps2cho's Avatar
E
reporting back upper arm did not solve noise.
going to disconnect sway bar to eliminate the bushings, then its either shocks/struts or tie rods/steering rack...
Old Mar 28, 2017 | 05:56 PM
cmriv's Avatar
do you have to be moving to reproduce noise?
