E-Class (W211) 2003-2009
E500 MERC 2005 HAS GIVEN ME HELL. HEAVY STEERING.
Old Mar 18, 2017 | 01:00 AM
DIMBS's Avatar
E500 MERC 2005 AVANTGARDE SALOON
INITIALLY WAS HEAVY WHEN TURNING LEFT. WAS TOLD TO BUY NEW STEERING PUMP. I CHANGED PUMP; PROBLEM PERSISTED. WAS TOLD RACK. IT WAS SOFT JUST FOR A DAY. THE FOLLOWING DAY, IT WAS HARD TURNING RIGHT. WAS TOLD RACK WAS FAULTY, FIXED ANOTHER ONE BUT STILL NO CHANGE. IVE CHANGED RACKS 3 TIMES, NO EFFECT. I HAVE NOW PARKED THE CAR.
Old Mar 18, 2017 | 09:21 AM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
Did you change the power steering hoses? Hoses can wear on the inside and then cause blockage. I would have started there unless the rack was leaking or pump was making a noise.
Old Mar 18, 2017 | 11:03 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
Is this a OEM MB rack? Did you replace oil tank for p/s fluid as well? Filter inside
tank can get clogged with debris and cause fluid restriction issues. Is there any air in the system?
Old Mar 18, 2017 | 11:04 AM
cmriv's Avatar
and what the fella above me said. Lines may be collapsed too
Old Mar 21, 2017 | 11:50 AM
gafitanu's Avatar
1967 250SE, 2022 GLC300 2023 EQB300, 2018 AMG GT
Check the speed controlled proportional valve in the steering gear.
Old Mar 21, 2017 | 06:29 PM
cmriv's Avatar
not all models obtained this feature. but its worth a look. I think if that valve is faulty it's going to throw a esp light.
Old Mar 22, 2017 | 12:26 PM
gafitanu's Avatar
The reason I pointed to the valve is because mine exhibits similar behavior when is cold outside for the first couple of turns after starting. It doesn't throw any codes and I can overpower it. It's quite expensive that's why I didn't change it.
Old Mar 22, 2017 | 06:22 PM
cmriv's Avatar
the part itself is pricey?
Old Mar 24, 2017 | 06:37 PM
arto_wa's Avatar
2008 E320 BlueTec, 1980 300 SD
New "Genuine Mercedes-Benz" Power Steering Proportioning Valve $405 at online vendor!
Proportioning Valve
You are not alone with W211 power steering issues - here are couple of links to what others have written:
https://mbworld.org/forums/e-class-w...-rack-bad.html
https://mbworld.org/forums/e-class-w...e320-w211.html
Not all W211 have the speed sensitive power steering.
Old Mar 28, 2017 | 05:54 PM
cmriv's Avatar
that is pricey sheesh. Well hopefully OP figured it out. I don't know if i've personally seen one of those valves bad. I've seen them leak but haven't drive a MERK with SPS with a bad valve. It would be nice if we knew whether or not he has code 213 (SPS)
