E-Class (W211) 2003-2009
front brake lock under hard braking
Old May 4, 2017 | 02:29 PM
Geeunit's Avatar
2003 E500
I have perused the forum to find a solution to my issue but haven't come across anything. (I am not the best at this so I may have overlooked something). Under hard braking and firm braking (dry pavement 40-50mph) I have had the front wheels lock up extending the stopping distance and causing flat spots on my tires. Obviously, ABS should not be locking the wheels for an extended period of time. I don't have any codes or indicators showing on the dash. After releasing the brake the car drives as normal. I am willing to throw some parts (a little $$) at it to fix the issue but I need a place to start. Am I looking to the wheel ABS sensor, the Yaw sensor, the ESP control module or the dreaded ABS block?
Old May 4, 2017 | 10:28 PM
cetialpha5's Avatar
Did you check your rear brakes? They might not be doing much back there so the fronts end up locking.
Old May 5, 2017 | 12:02 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
You have SBC?
How old is brake fluid?
Old May 5, 2017 | 08:19 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
gonna bet there's a code stored somewhere. What is it?
Old May 5, 2017 | 12:32 PM
Geeunit's Avatar
2003 E500
I will give these a shot.
I don't know how old the fluid is, I just got the car. I will have it changed.
The rear pads are low, and seem to be putting out a lot more dust than the fronts, Im thinking they are a different compound. I will change them.
Yes, it has the SBC and definitely feels different.
Will a trouble code be stored somewhere that can be retrieved even tho there are no indicator lights on the dash?
Is a scanner like Actron 9680 capable of retrieving these codes?
Old May 5, 2017 | 12:53 PM
cMazara's Avatar
w211 03'
Yes, codes are stored. You'll have the codes stored until you clear them with a das.
Old May 5, 2017 | 02:59 PM
kajtek1's Avatar
I would not worry about it now as you can clear the code next week, or next year
BUT for brake flush you need SD level scanner. Hook up your Actron and see if it will give you SBC options. Don't hold your breath.
Since it is new car to you, you have to start with basic.
- fluid flush
-new pads since old one are questionable (Akebono are recommended)
-rotors careful inspection
-ABS and reluctor rings careful inspection.
Old May 5, 2017 | 03:01 PM
cetialpha5's Avatar
I'd check the calipers also and that the glide pins are properly greased.
Old Jun 16, 2017 | 09:59 AM
Geeunit's Avatar
2003 E500
update so far
Actron 9680 only reads engine codes, so I bought a icarsoft MBII.
Replaced 4 tires to remove vibration from flat spot.
Observation: The backup battery under the hood looks to have been replaced recently.
Codes pulled: C11B3 steering angle sensor has failed several times -performed relearn procedure and cleared code.
P2403 left front wheel rpm signal sent from the traction system via the can bus is implausible (bingo! -same wheel that is locking up)
9076 CAN communication is faulty
9010 the supply voltage of the control unit is too low
SRS light was on- cleared code and reset.
Some error to do with left side fuel level sensor? -just had warranty work done on top of tank so I just cleared the code
After resetting the steering angle the ABS light came on and has stayed on.
To Do List: Going to check the LF ABS sensor and reluctor ring. Of note I haven't seen a replacement procedure for a ring w/o 4 matic option. Is it unitized with the hub?
I have new akbono pads for the rear (had them on my old 210 )
MacGyver a pressure bleed system for the brakes.
Question; are the 9XXX codes significant, (A real problem?) or just residual with the LF ABS issue?
Am I on the right track?
