E-Class (W211) 2003-2009
Car braking by itself. Triggering sbc fault
Old Aug 3, 2017 | 02:43 PM
cMazara's Avatar
w211 03'
My car had sbc pump gone bad, it felt like the front left was braking by itself then the sbc fault came on, lucky the second brake system works. I changed the pump yesterday but it has the same issue. Two different pumps and the same issue... I don't have a clue as to why this is happening. A guess is that the front brake pads are squeaking like the are done, like metal to metal, I wanted to change the pads after fixing the sbc.. guess is could it be that they changed the sensor but not the pads then the car is braking more or less and then thinking it's the sbc? Any other idea? The new sbc pump sounds loud like when it's on the bleeding procedure then the red sbc comes on. Park it a few hours he the fault is gone until I drive it.
When I drive it without the fault it stars to shake like when you are braking and pads/disc are not aligned but in this case I don't even touch the brake pedal.. so it's deft braking by itself then triggering the sbc.
sorry for the long post, tried to explain it by all means possible.
Old Aug 3, 2017 | 11:07 PM
cMazara's Avatar
w211 03'
yoooo. Any1 plzz
Old Aug 3, 2017 | 11:27 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Did you scan the car for codes?
How about programming new pump to the car?
Old Aug 4, 2017 | 12:48 AM
cMazara's Avatar
w211 03'
Yes, related to the sbc it was just the sbc fault..
well in the das I saw that where it show the fault it said to fix it there, so he press the start and proceed to bleed... is there another way to program a pump? this is a pump with a different part number than the previous, but this is the correct one for the car, i search it with the vin and this is one of the few compatible with my car.
tomorrow i will go again and check what the codes say now.
just ideas for tomorrow as i will have the das connected and the mechanic.. something else to look for?
Old Aug 4, 2017 | 05:49 PM
kajtek1's Avatar
We have great pictorial on the forum about SBC replacement and resetting. Just look for it.
Old Aug 8, 2017 | 10:58 PM
cMazara's Avatar
w211 03'
Seems like it's solved.. Changed front pads which were worn to the metal plus the sensors were not installed correctly.. Also the central gateway module was replaced by the previous owner and had different coding for a 240, mine is a 320, so the sbc pump and other features were not communicating correctly, nonetheless I' going to get a new central gateway and program it with my vin. Hope the sbc last 2 year at least.
Old Aug 10, 2017 | 06:21 PM
kajtek1's Avatar
SBC last for about 600,000 pedal pushes.
For me that would probably make 20 years, but I know people who manage in less than 2.
Old Aug 18, 2017 | 06:16 PM
Maroc_Specops's Avatar
W211 E320 CDI Sportpackage With Carlsson CD32 Chip 2004
the updated pumps have infinite counter. Just for the know how.
Old Aug 21, 2017 | 05:51 PM
bernard farquar's Avatar
2011 E350, 1998 ML320
Oh! I had not heard this, does anyone know if the pumps that a US dealer would have used to replace a failed SBC unit under the extended warranty would have an infinite counter?
