Rear Differential to Subframe Mount Bushing
Subscribe
Oct 15, 2017 | 01:59 PM
My car is 2008 W211 BlueTec (VIN: WDBUF22X58B236356) with just over 150,000 miles on it.
Wile checking things out in preparation for differential oil change next weekend, I noticed there is only one rubber bushing and empty hole for another one.
MB dealer part diagram shows only one bushing being used, but it sure looks odd when looking at it while under the car!
Just curious, if other members have noticed this and is this really how it should be or did one bushing fall off?
Rear differential to suspension crossmember rubber bushing.
Reply 0
Oct 18, 2017 | 11:21 AM
Quote: My car is 2008 W211 BlueTec (VIN: WDBUF22X58B236356) with just over 150,000 miles on it.
Bumping this up.
Come on guys - over 50 views and nobody else has noticed missing bushing?
Reply 0
Oct 18, 2017 | 12:29 PM
I've looked around a bit and from I've seen, there is only one bushing. We have one available and when I took a look at it, there is only one bushing as well. It does seem odd. My only guess would be the sub-frame is used between different models and perhaps a different model may utilize that whole. Perhaps somebody else will chime in with more information!
Reply 1
Jun 1, 2019 | 08:23 PM
My 2008 E320 Bluetec looks the same
Reply 1
Jun 1, 2019 | 09:43 PM
Quote: My 2008 E320 Bluetec looks the same
Levi,
Thanks yes it looks odd, but that's how they were built apparently.
Reply 0
Oct 13, 2019 | 01:02 PM
Same, only one Bushing on left side. 2005 E500
Reply 1
Mar 10, 2021 | 05:08 PM
Old post but, this is how it should be, on the AMG versions 55 and 63 there are two bushes.
Reply 0
Mar 19, 2021 | 03:41 AM
I wonder if there would be any benefit in adding the other bushing, or if it would just increase NVH unnecessarily.
Reply 0
Explore
Jun 21, 2022 | 03:03 PM
Can anyone tell me what tool I need to remove this bolt?
Reply 0
Jun 21, 2022 | 04:49 PM
Looks like a standard 12 point drive. I’ve seen them on Mercedes head bolts. Probably 12mm but I can’t tell the size from the image.
Where is it? The bushing looks like a Torx screw.
Peter
Reply 0
Jun 23, 2022 | 05:12 AM
That would be the external XZN socket. Size, not quite sure as I've not yet needed to play with them. Only with hub nut on VW and BMW what goes with the XZN's. But what I googled, I *think* that size is corresponding to the thread size of the bolt. At least many advert them from size M12 to M18, for example.
Reply 0
Subscribe
Currently Active Users (1)
