E-Class (W211) 2003-2009
Need to replace front struts
Old Nov 2, 2017 | 01:36 PM
MBE350jaybee's Avatar
E350 4matic
2006 E350 with 110K - snapped the front spring coil. Planning to replace both side with new struts. Question should I go with OEM or a different type?
I just drive normal and thought it drove fine as original. Didn't feel too boaty/floaty.
Where's the best place to order new parts - have a line on OEM on Ebay place for $375
Thanks in advance for you assistance
Old Nov 3, 2017 | 12:28 PM
ps2cho's Avatar
E
what do you mean by snapping the front coils?
make sure you replace the strut mount at the same time
Old Nov 3, 2017 | 12:58 PM
mtrevelino's Avatar
2006 E320 CDI
Where are you located that your spring snapped? I am guessing you are located in a cold climate.
Mike T.
Old Nov 3, 2017 | 01:50 PM
E350 4matic
Coil around the strut = Over Coil ? It just snapped at low speed and not very cold. I don't remember hitting a bump or anything. It was Spring time and I had just replaced my rear axle on the driver side. Then later noticed the passenger side was really low. I'm at the Ohio/Michigan border and there are a lot of pot holes.
I was really busy this summer and have another car so I am just getting to this.
Old Nov 3, 2017 | 01:54 PM
E350 4matic
Mike T.
I bought the car in Kalamazoo Michigan - where it's cold but not too bad 2006 thru 2013 then drove it to Phoenix AZ and lived there until 2015; transported to Charlotte NC and drove it to Toledo Ohio 2016 Spring and here now.
Old Nov 3, 2017 | 09:43 PM
mtrevelino's Avatar
2006 E320 CDI
I was thinking of road salt and chemicals eating the springs. Normally you hear these stories from those in the harsher winter climates.
Mike T.
Old Nov 4, 2017 | 11:46 AM
E350 4matic
Here's a better picture plus the bolt broke too easy - first attempt after wd40 and with a short handle.
now concerned about the level of corrosion.
Old Nov 4, 2017 | 12:34 PM
arto_wa's Avatar
2008 E320 BlueTec, 1980 300 SD
Here is a good place to start - check out their tech help articles also:
http://www.pelicanparts.com/Mercedes-Benz/index-SC.htm
