E-Class (W211) 2003-2009
2003 E500 w211 ways to bag the car want to go up and down
Old Nov 15, 2017 | 09:07 PM
David Quintero's Avatar
2003 mercedes Benz E 500 w211
I'm trying to bag my car and the set up are expensive i just bough my e500 and the previous owner just instal all the air shocks on the car is there anyway that I can use the oem air shocks to lower and raise my car by just buying the silinoids and air tank can anyone help me out and I think my compressor just went out too. Or is there a post that someone did this already let me know . I know there is lowering links. But my car is already low and my compressor when out already
Old Nov 16, 2017 | 06:34 PM
Redwood415's Avatar
92 W124 500E, 93 W201 190E, 11 C207 E350, 05 W211 E55
I would advise to not drive the car at all at that extreme low ride height. Why not just replace the compressor? There is a way to slightly lower the default ride height using the SDS computer but it will not be adjustable from the cab other than the "raise vehicle" button. I'm sorry to say but these motorcars are not meant to have wild adjustable ride heights.
Old Nov 16, 2017 | 11:47 PM
Is just want to go a little bit lower then stock cuz I just bought these rims i want to go low buy the edge of the tire my wheels are 19x9.5+45 all the way around and the going up part is on my driveway that is a little steep nothing mayor
Old Nov 17, 2017 | 01:12 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Sounds like a lowering module would be the way to go. Just fix the issue with your compressor.
The Programa module is $600.
Old Nov 17, 2017 | 01:15 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
you can lower your car at least 1" by adjusting sensor rods.
Old Nov 17, 2017 | 10:15 PM
They don' sell it for the e500 any cross refeence that I can use
Old Nov 18, 2017 | 03:37 PM
Strigoi's Avatar
Which post is this in reply to?
Old Nov 27, 2017 | 12:21 AM
Strigoi , 11-15-2017 07:48 PM
How low are you trying to get the car? Just fix the compressor and get a lowering module unless you're trying to go super low. Another option is to remove the whole airmatic system and install coil overs.
Lowering module: http://www.programainc.com/product_d...aspx?sf=LCMR01
You should also be asking your questions in the W211 section. The New Members section isn't really the place to ask this type of stuff since it doesn't get a ton of traffic.
https://mbworld.org/forums/e-class-w211-20/
Old Nov 27, 2017 | 10:07 PM
Strigoi's Avatar
The Programa lowering module will work on your car.
There's a ton of threads on here about lowering modules. Read up on them so you know what you're getting.
