E-Class (W211) 2003-2009
Electronic Trunk Closer
Old May 9, 2004 | 05:45 PM
lyrixmajor's Avatar
2004 E500 w/ AMG Sport Package
Can you add the Electronic Trunk Closer after your car comes from the factory
Old May 9, 2004 | 09:06 PM
northbenz's Avatar
sl and M-class E320 4Matic SLK350
No
Old May 10, 2004 | 01:11 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Electronic Trunk Closer
Yes.
People have retrofitted COMAND, heated seats front/rear, folding mirrors, autodimming mirrors, active cornering lights, distronic, etc. So there's no reason that this could not be retrofitted. It's significant work, but can be done.
There is a class of items that is extremely cost prohibitive to retrofit, and that includes those that are directly tied to the VIN of the car: locking/security items, and TeleAid.
-s-
Old May 10, 2004 | 02:06 AM
northbenz's Avatar
The dealers will tell you this is not an option that can be added. To my knowledge the parts departments do not have a kit that would allow addition of this option. Obviously anything is possible if you want to go to a specialist outside of the dealership and hand over a blank check.
Old May 10, 2004 | 03:31 AM
nellee's Avatar
2002 CLK320
Talking
If it can be added from the factory, then Steve can do it one step better!
Hand over your car to Steve for a day, and he can do wonders to it.
Old May 10, 2004 | 05:01 PM
SUNILP's Avatar
2015 E250D
YES YOU CAN 100% install the trunk closer. You will need the following items:
Trunk Motor
Small harness to rear SAM unit
Front Left Switch assy replaced with new one with trunk closer button
Trunk Latch replaced also with electronic one.
harness from Latch to rear SAM unit.
You can also retrofit Distronic for around 4 grand. The trunk closer should be around 1000 dollars.
Old May 10, 2004 | 05:17 PM
IluvS500's Avatar
Jeep Grand Cherokee Overland
Trunk Motor
so are you saying that, if in the future here, I end up buying a used S500 without the trunk closer, you would know how to do it?? 1000 dollars is not bad at all. I figured it would be atleast double that. Let me know, cause down the road from now I might be interested.
Old May 12, 2004 | 12:35 PM
IluvS500's Avatar
who would do it for me???
Old May 12, 2004 | 12:37 PM
t-bone's Avatar
2004 E55
Steve could do it. I don't know if he would though.
Old May 12, 2004 | 02:12 PM
scorchie's Avatar
I don't think he would do it on an S-class... a W211 E-class maybe. We started this discussion about E-class... and then someone assumes that the pricing and ability applies to an S-class? No, it doesn't!
-s-
Old May 13, 2004 | 10:29 AM
IluvS500's Avatar
-s-
im sure it would be close though, if not simple on the s as it already has some of those parts mentioned. I will ask when the time comes.
Old May 13, 2004 | 10:29 PM
SUNILP's Avatar
2015 E250D
I don't know the prices for the S class but the estimate was for the w209 CLK which uses many of the same parts as the E class. The E class Wagon closer is different though. IT's hydralauic since it weighs more. THe sedan is a electric high torque motor connected to rear SAM. Star Diag may have to be used as well to activate it.
Old May 14, 2004 | 05:08 PM
lyrixmajor's Avatar
can someone recommend someone in florida or on the east coast that can get this done for me?
Old May 14, 2004 | 05:30 PM
IluvS500's Avatar
I dont know exactly how on the S it works, all I know is that there is a like cord thing on the right side of the trunk lid that connects to somewhere on the car. I think there is a motor in the trunk lid that pulls it down, cause you can hear the motor and thats where it sounds like its coming from.
Old May 16, 2004 | 07:21 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
...that cord is just wiring for whatever there is to be wired in the trunklid (license plate lights for example)...
The trunklid closer is to be found in the trunk and operates one of the hinges...
Personally I don't think that this option can be added (to a W211) for anyprice close to 1000USD...the motor needed for the trunkclosing system itself already costs a minor 1000USD...
greetingz,
Old May 16, 2004 | 11:06 AM
SUNILP's Avatar
2015 E250D
Steve,
The dealer quoted me around 400 dollars for the motor for a clk. He may have been wrong then
Old May 16, 2004 | 11:31 AM
IluvS500's Avatar
greetingz,
Are you talking about on the hinges of the w220 because I dont see where you would mount it exactly, last time I looked I didnt see anything out of the ordinary on it either.
Old May 16, 2004 | 03:09 PM
SUNILP's Avatar
2015 E250D
You can't really see the motor since its hidden well inside the trunk liner on the left side and attached to the hinge
Old May 16, 2004 | 04:14 PM
scorchie's Avatar
On the S-class it does not work like that because the S-class has external hinges... not external to the deck lid like a 90s Ford Mustang, but external to the trunk.
Can we move this to the S-class forum instead if we're not talking about W211 trunk closers anymore?
-s-
Old May 16, 2004 | 05:44 PM
IluvS500's Avatar
-s-
were still talking about both, just got a little side tracked
Old May 16, 2004 | 07:05 PM
scorchie's Avatar
Oh OK, sorry... never mind then.
-s-
Old Jun 26, 2004 | 04:52 PM
SUNILP's Avatar
2015 E250D
i looked into retrofitting the trunk closer and yes it is possible. There is a retrofit document in WIS that I have for the 220. The 220 S class is a bit harder. It is a hydraulic system. CLK has a electric motor. E Class Sedan is electric and E class wagon is hydraulic. It all depends on the weight of the trunk door. But yes it is doable 100% CLK motor is 450 dollars and electronic lock latch mech is 250 dollars. Switch is 60 dollars and wire harness another 80 bucks. S class is probably much more money.
