2005 E500 No Crank No Start
I was pretty sure it was the crankshaft position sensor because the car seemed to only start after cooling down and the sensor as I understand heats up loses contact and then resettles into a closed
circuit when it cools but I replaced it and the car seems to start with no problems only when it wants too, cant say it another more specific way unfortunately.
I have replaced or checked:
brake light switch
charged battery in trunk
check AUX battery
Also and something I am sure is related is that recently I would say 2 weeks ago I noticed that on uneven ground I would not be able to shift from drive into reverse the shifter would not allow me to go past neutral.
Later I noticed I could shift into any gear without pressing the brake. This morning the car turned on no problem but would not allow me to shift out of Park, so I turned it off. It wouldnt start the next few times I attempted
to do so, although I am sure it would start if I went out there right now. I have opened the gear shift selector by removing the console but I am not sure what to look for. Any ideas as to why it turns on at random? I am able
to turn the key all the way to the right and the lights work and everything but its almost exclusively a no crank no start unless it starts I think once it cranked for a half a second but never started. Any advice I would appreciate.
brake light switch
check AUX battery
had the pump replaced at an independent shop (currently waiting for reimbursement). The guy who serviced the pump isnt who I normally go to and I have doubts
about his work but the pump was replaced a day before the tank was inspected and replaced by Mercedes so I am and have been assuming that they would have
noticed something wrong with the pump when they replaced the tank and tested for functionality. It does seem like a fuel sending issue but it could be so many other
things to be honest its overwhelming. I ordered an icarsoft MB II and it will be here this thursday so im hoping that it will lead me in the right direction. How would I know
or verify if the fuel pump is sending fuel when the car doesnt start, remove rear seat cushion? what am i looking for the actual fuel lines or just listening to hear the pump
turn on?
Also is there a relay associated with the fuel pump, can anyone tell me where it is?
thanks for everyone's opinion I will keep all of it in mind. I just got the carsoft mbii in the mail and ill see what codes come up soon. The car started on two consecutive attempts since my initial post but since then i have had the negative cable disconnected so I dont know if tapping the fuse pump relay and re seating the connections under the drivers side rear seat actually did anything (one of the wires in the main connector appeared loose to me but im really stretching for an answer here)
I am going to get a new battery under warranty I just want to rule that out for sure 100%
