E-Class (W211) 2003-2009
E500 Wagon going to coilovers
Old 05-05-2018, 08:57 PM
Onyxthecat's Avatar
06 E500 4Matic Wagon
Hi everyone, I just bought a 2006 E500 wagon 4matic. I drove the car from Oklahoma to New York with no issues except the white logo on the gauges saying visit workshop with the up arrow. Today the front passenger side was slammed and the red alert of the car being to low appeared. From all the countless threads of this issue with the airmatic system, I'm doing the coilover swap. I have installed coilovers before so I have some experience. I'm thinking the BC set(which I don't fully know will work) and the strutmasters set but I can't find any others that will work on a 4matic wagon. If anyone knows what coilovers will work on an 06 E500 4matic wagon, please let me know.
Old 05-06-2018, 01:53 AM
kajtek1's Avatar
Received 1,749 Likes on 1,394 Posts
1922 Ford Model T / no OBD
How do you plan to adjust wagon level with heavy load?
Old 05-06-2018, 08:45 AM
Onyxthecat's Avatar
For that I'm not really sure.
Old 05-06-2018, 03:05 PM
Onyxthecat's Avatar
After doing more research and counting in my free time( which is almost 0 with a 2 year old), I'm going to just replace the front right air shock with an Arnott unit and hope that's all I need. I also ordered an iCarsoft MBII for diagnostics. I did listen to the compressor run last night and I could hear what sounded like a lot of air escaping from the shock while watching it not even raise slightly. I sprayed soapy water on the valve on top of the shock and saw no bubbles so my guess the leak is somewhere else.
Old 05-06-2018, 03:17 PM
kajtek1's Avatar
If you have original bags being 13 years old, yours hold better than average, what is about 10 years.
Arnott is hard to beat with its lifetime warranty, but I always ask "who's life we are talking about?"
Still your compressor works big overtime now, so have it rebuild at bags replacement. $15 kits on ebay.
Old 05-06-2018, 03:23 PM
Onyxthecat's Avatar
I'm not sure what you mean about having the compressor rebuilt from ebay? Can you link me to a kit? I'm not driving the car until i fix the leak. Also, I have no idea how old the bags are but they look original, is there a manufacturing date on them?
Thanks!
Old 05-06-2018, 03:26 PM
kajtek1's Avatar
https://www.ebay.com/itm/Mercedes-S-...19.m1438.l2649
It is $23 now, but still cheap. I made compressor rebuild pictorial in this section, so check it for guidance.
Old 05-06-2018, 04:02 PM
Onyxthecat's Avatar
link does not work
Old 05-06-2018, 04:08 PM
Veteran: Army
bbirdwell's Avatar
Received 1,014 Likes on 787 Posts
'99 and '05 E55 AMG
Originally Posted by Onyxthecat
link does not work
Worked for me. Here's another link to the same page.
https://www.ebay.com/itm/151604325097?rmvSB=true
Old 05-06-2018, 04:25 PM
Onyxthecat's Avatar
Great thanks, I found the kit that will fit my car. What is the advantage of this over just buying a new compressor?
Old 05-06-2018, 08:25 PM
kajtek1's Avatar
About 450 bucks.
Old 05-07-2018, 01:32 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Do the Arnott replacement or go with coil overs. Don't **** around with some cheap Ebay rebuild kit.
Do you actually haul heavy stuff in your wagon or is it used the same as a sedan would be while looking much better?
My g/f and I went up to Mendocino this weekend for a friend's wedding. She didn't understand why I got all excited over seeing an E63 wagon going the other way on 128 (we were in my E63). They look better, that's why.
Old 05-07-2018, 09:04 AM
Hotsauce55's Avatar
2005 E55
I'm converting to BC coilovers now but don't have many times per year where I am wickedly loaded up
If I had a wagon & using it to haul around things I'd keep the air & go with Arnott no questions asked
Don't be cheap with these cars, its impossible
If you go to the common maintenance thread in the E55 section, I think someone found a link to a new pump for $1xx.xx
Old 05-07-2018, 06:46 PM
Onyxthecat's Avatar
I love wagons and I will haul stuff so Arnott air is the way to go. If I have to replace the pump and the rest of the bags with Arnott units I will just going to do the one for now. Thanks for the help guys.
Old 05-13-2018, 11:21 AM
Onyxthecat's Avatar
UPDATE: I replaced the strut with a new Arnott unit and after I discovered the line was cracked which is why it was leaking. The crack was hiding under a bunch of wiring and I did a temp jb weld fix which is holding fine. I'm glad I did the replacement though and I plan on doing the other side as well. These seem to be original with the car and at 151K it should be done. Now that I know how to do the install and what is involved, the other side should go quickly.
Quick Reply: E500 Wagon going to coilovers
