Smells like Sulphur after hard acceleration
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
I wonder if any E500 owners out there have experienced this smelly problem? When I pull into my garage, sometimes I notice a strong sulphur (rotten eggs) smell from the exhaust area. Usually this occurs after hard acceleration, and only if the aggressive driving precedes a long period of mild mannered driving. I took the car into my dealership and apparently the technician could not duplicate the smell. I'm no expert, but I think the catalytic converter is not warmed up. But lately the smell is diminishing. Any tech guys out there who can share some info?
'03 Yukon XL Denali, '06 Eclipse GS
Possibly the burning smell of the fuel? My W211 smells somewhat of what you're describing after a hard push on the vehicle. I also shift gears a lot, so that may be the case.
No it's not shot and MB had a TSB out about the sulfur smell, there was a flash update involved. My 04 and my 03 CLK 500 has/had the smell too and is seeming to get better with more mileage.
'03 Mercedes E320
zzoorrkk: I'd suggest you also try a few tanks of a different brand of premium name-brand gasoline. Brand additives can influence the converter odor, and might resolve it.
Hi guys!
I have the same sulphur smell in my car....I have a E220 CDI and this nasty smell is there when the car warms up. I was thinking it could be the high sulphur content in the diesel?? Maybe I should ask MB service to check the cat??
Here's what may be going on:
How catalytic converters work
Eggbert and Shelley were driving home from the market when they stopped at a red light behind a new minivan. As they waited, an unpleasant, rotten egg smell permeated their sedan, and they realized the offensive odor was coming from the minivan. "Why does that new minivan smell so bad?" asked Shelley. "Oh, that's the catalytic converter," replied Eggbert. "It's not working properly, so some bad fumes are coming out in the exhaust." "What a shame," lamented Shelley. "A new car and the converter is broken already." While the couple puts away their groceries, let's get an SwRI Whizard to tell us what's going on.
"Did Eggbert and Shelley correctly identify the problem? Well, yes and no. The smell was caused by the catalytic converter, but it wasn't broken. In fact, the bad smell is a sign that the converter is working quite well. It doesn't need to be fixed, and the smell will go away with time.
"So what is that awful smell? It's hydrogen sulfide or H2S. It does not exist in the fuel or oil, which is why you can't smell it at the gas station. It does, however, come from the gasoline. Almost all gasoline contains organic sulfur compounds with sulfur levels ranging from 30 to 100 parts per million, approximately.
"As the fuel burns, the organic sulfur compounds break down into simpler compounds. If the engine is running lean (more air than is needed to burn the fuel), the sulfur is likely to be SO2, or sulfur dioxide. The catalytic converter can change this into SO3 (sulfur trioxide), which then reacts with the catalyst to form sulfates on the catalyst. Over several minutes there is a build up of sulfates. If the engine suddenly starts to run rich (not enough air to burn all the fuel), such as when you stop at a red light, climb a steep hill, or brake hard to slow down, the chemistry changes. Now the sulfates are unstable and they react to form hydrogen sulfide, which is expelled from the exhaust pipe all at once. The high concentration is the reason for the bad smell! This effect is a common problem with new vehicles because the catalyst is working at a very high efficiency. However, as the catalyst gets older, the activity drops. Fortunately for us, one of the first reactions to be affected is the formation of hydrogen sulfide. So as the catalyst gets older, the smell will go away. It should also be noted that many catalysts never smell bad. One reason might be because the vehicle doesn't run lean for much of the time, or perhaps the catalyst has an extra component that reduces the production of hydrogen sulfide.
"Next time Eggbert and Shelley stop behind a vehicle that smells bad, they can be grateful that it's at least not contributing much to atmospheric pollution."
Thanks to this month's Whizard, Dr. Gordon Bartley, a senior research scientist in the Emissions Research Department of the Automotive Products and Emissions Research Division. Bartley specializes in the development, aging, and evaluation of vehicle emission catalysts.
The Lighter Side SwRI Home
May 21, 2004
May 21, 2004
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
Holy Cow, Batman. That's why the smell is diminishing... so my catalytic converter is OK then... Thanks guy!
May 21, 2004
May 21, 2004
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
Foul smell..
with over 100k kms and the smell is still there. I have no performance issues and the smell is stronger when cruising on the highway. Will the smell go at some point
May 21, 2004
May 21, 2004
