brake pedal vibration in 2004 E320...
2014 C250 sport
hey!! has anyone noticed a vibration and a buzzing noise through the brake pedal when you step on the brakes?? Also, after starting the car, somethings starts buzzing for about 10 secs then goes away..is this normal or has something to do with the SBC??This has been going on since the car was brand new, but the brakes work just fine.....
PS--has anyone noticed that most 2004 E320 wagons are 4matic??I know the E500 comes standard with it, but even the E320's I see have 4matic....just curious
2014 C250 sport
The E500 wagon does come standard with the 4matic
the build of the car is 10/03. It's my grandpas car, but I have noticed it when I have driven it
'03 Mercedes E320
An SBC pump will run to keep up the pressure, both during operation and sometimes when the door is first opened. Mine makes a muffled pump sound, is not objectionable, and has done so since new. Some people either have a loud vibration or find the sound objectionable. The pump is a normal sound, however.
2004 E500 4MATIC
akbro,
When you say "stepping" on the brake pedal, do you mean just generally or do you mean REALLY stepping on them? Standing on the brakes in a panic stop can activate the ABS, in which case you can feel vibration from the rapid opening and closing of the calipers on the rotors.
As for me, I've never noticed any sounds or vibrations in general braking.
Brake pump noise way to loud
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
That noise and vibration has been bothering me every time I drive my car. I'm gonna take my car to the dealer for its first maintenace in couple days (been back to the dealer more than 5 times for warranty work), hope someone can provide a fix to it.
And there is one more thing, does all of your brake pedal make a "click" noise everytime you step on it?? ....cuz none of my other cars does this including my clk....
There are 2 mods avbailable for this - severity varies from car-to-car....
1. There is a software update - this has done little on my 05 model w211 270CDI - not much change....
2. Apparently the pipes to the compressor can be cahnged - this is a bigger job, will not completely remove the probelm but should help. I plan to have this done at my first service.
Wierd though isn't it....
2015 ML 350
I had a "click" on another (non MB) car. On that car it was the plunger on the brake light switch not popping out immediately as the pedal was pushed down, and it popping out a second later to its fully extended position. Step on the brake while backed up to a wall & observe if the brake lights come on immediately.
Assuming MB has this type of switch... but it might have some other switch resting against the brake pedal "arm".
