E-Class (W211) 2003-2009
secondary air pump issue
Old Sep 19, 2018 | 06:07 PM
bruce24's Avatar
2003 E500
Pump was not working it seized up i opened it up cleaned and lubricated it tested it 12v and it worked. 40A fuse was bad so i replaced it and waited for the car to cool down. Upon starting it few seconds in fuse brakes i tried another one it also brakes. Could this be short somewhere or is the pump just bad
Old Sep 20, 2018 | 12:22 PM
F1Fan's Avatar
Did you check the relay? If not, try google searching for the secondary air relay. I believe the part is made by Hella.
Old Sep 20, 2018 | 01:01 PM
bruce24's Avatar
2003 E500
I tried the relay on to my other w211 and it works so it's not the relay. Pump does not attempt to do anything fuse just pops. I am thinking to take the pump from my other e500 and see if it will work
Old Sep 20, 2018 | 02:35 PM
F1Fan's Avatar
Good thinking. Won't cost you anything to test the other air pump. By any chance, would you happen to have the part numbers for the small vacuum hoses that connect the two valves?
Old Sep 20, 2018 | 02:56 PM
konigstiger's Avatar
'71 Pinto
https://www.pelicanparts.com/techart...ts_Testing.htm
Old Sep 20, 2018 | 03:00 PM
'71 Pinto
211.070 (e500) which item(s)...
Old Sep 20, 2018 | 03:43 PM
bruce24's Avatar
2003 E500
As always thank you ok it is the pump took one from my other car and it works I am thinking this pump has a short somewhere Thank you for your help
Old Sep 20, 2018 | 11:18 PM
F1Fan's Avatar
Can you let me know the part number for item 101, 107, & 119?
Old Sep 21, 2018 | 11:29 AM
'71 Pinto
Old Sep 21, 2018 | 06:39 PM
F1Fan's Avatar
Excellent! Much appreciated!
