E-Class (W211) 2003-2009
Bad MAF sensor ?? Please help
Old Sep 21, 2018 | 04:48 AM
Mihai Bivol's Avatar
W211 E CLASS 220 CDI
Hi everyone !
When I start the car E220 CDI, engine feels like it's stalling, rough idle,engine shaking...etc..
While Idle, I disconnected the MAF sensor plug and engine stopped shaking and sound better.
Can it be a problem with the MAF sensor ?
Old Sep 21, 2018 | 10:33 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
codes?
Old Sep 21, 2018 | 10:58 AM
No codes, I mean that I simply disconnected sensor and engine stopped shaking...etc
Old Sep 22, 2018 | 04:14 PM
E500benz203's Avatar
E500
probably dirty or faulty maf...still can be something else though… we can get more technical with scan tool data if you have it.
Old Sep 24, 2018 | 02:48 AM
So...took the car to Mercedes specialists.
fault on MAF sensor found and also fault on air intake temperature sensor....
It's only 66.000 miles car...and so many faults. Very surprised
Old Sep 24, 2018 | 02:39 PM
kajtek1's Avatar
Intake temp sensor is part of the MAF from what I know?
When my son had MAF failing on his ML320, he had 10 codes, when the car still drove without symptoms.
New MAF resolved them all.
With bluetooth OBD scanners selling for less than $10, you have no excuse not to own one.
Old Sep 24, 2018 | 10:04 PM
E500
yeah just replace the maf. as someone else said, the IAT sensor is built into it. I just replaced mine today quite coincidently.. ordered mine from amazon.
Old Sep 27, 2018 | 02:37 AM
Still bad
Replaced MAF sensor, still the same issue.
And only with cold engine. If I start the engine and leave it idle for 1min and after that rev it till 2000rpm , engine start to work rough.
Also when I switched ON ignition, I can hear a strange sound coming from the engine - maybe common rail system.
See the link below
https://m.youtube.com/watch?v=Py_SNYzNi_8
Old Sep 27, 2018 | 11:39 AM
LexBrett2's Avatar
2007 Mercedes E550
Have you considered the Crankshaft Position Sensor?
It will give a code P0335 when it fails, but sometimes it won't give a code at all.
Usually stalling, hard starting occur just before it is about to fail.
Old Oct 25, 2018 | 02:46 AM
Originally Posted by kajtek1
codes?
Codes
Old Oct 25, 2018 | 02:47 AM
OBD SCANNER
The following codes appeared on OBD 2 scanner
