E-Class (W211) 2003-2009
changing the station by steering wheel buttons
Old Jun 14, 2004 | 02:35 AM
synchronictyii's Avatar
On my old 02 C320 there was a way to set the steering wheel buttons to change the radio stations by presets instead of by going up to the next available station numerically. I've been trying to figure it out on my new E320, but have had no luck, I couldn't find anything the owners manual either. Does anyone know how to do this?
Thanks.
Old Jun 14, 2004 | 04:09 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
You did one good thing and one bad thing.
The good thing was you checked your owner's manual first.
The bad thing is you did not STFF (search the fine forum).
Through judicious application of the search function, you can elevate yourself to enlightenment.
-s-
Old Jun 14, 2004 | 08:47 AM
miroj's Avatar
Re: changing the station by steering wheel buttons
Thanks.
The personal settings are adjusted to "scan" and not "preset" mode.
You will find them in the instrument cluster control panel.
Old Jun 14, 2004 | 08:48 AM
miroj's Avatar
-s-
I typed fewer words and got the answer out .... is judicious the same thing as useless ?
Old Jun 14, 2004 | 10:24 AM
Barry45RPM's Avatar
2015 ML 350
Except that on the '03 & '04 E Class there is no way to set up the preference for the radio to scan to the next pre-set station from the wheel, or anywhere else. Its is NOT a choice to be selected in settings or anywhere else. It will always scan to the next frequency that is on air. The '02s had the choice available to the owner in "Settings", but NOT the NEW E Class (W211's) in the USA.
Old Jun 14, 2004 | 01:08 PM
scorchie's Avatar
Had you yourself done a search, you would know that this is not possible.
Even if your answer was the correct one, it would be cluttering the forum with repeated answers... thus reducing the effectiveness of the search function.
-s-
Old Jun 14, 2004 | 01:38 PM
ok, thanks Barry45RPM and miroj. I thought that it might not be possible, because I couldn't find anything. And scorchie, you are such a loser that you actually took the time out of your day to reply to a question with a smart *** answer just to get your rocks off? wow.
Old Jun 14, 2004 | 02:15 PM
scorchie's Avatar
Umm, OK, whatever... you're so selfish that you can't understand that this should be a resource for everyone. But you're too lazy to do a search, and you now have two conflicting answers... only one of which is correct, and you don't know which.
Good luck. And into the ignore bin!
-s-
Old Jun 14, 2004 | 02:58 PM
Brav's Avatar
07 M6, 05 Noble, 01 S4, Smart ForTwo
It would he 1000% more helpful if you included your location by your avatar since you obviously dont live in the states.
Old Jun 14, 2004 | 03:00 PM
Brav's Avatar
You wouldnt know right off hand, but this topic has been beaten up over and over for the past 2 years.. hence the frustration.
Old Jun 14, 2004 | 04:15 PM
"You wouldnt know right off hand, but this topic has been beaten up over and over for the past 2 years.. hence the frustration."
what frustration, just ******* ignore it, instead of taking the time to reply with a stupid comment.
"Umm, OK, whatever... you're so selfish that you can't understand that this should be a resource for everyone."
resource for everyone? ok, how am i using up other people's resources? by taking up one line in a forum that consists of about thirty or so threads per page? you're an idiot.
Old Jun 14, 2004 | 04:29 PM
Barry45RPM's Avatar
2015 ML 350
By and large the people on this forum are awesome! The help is immense, usually right on & faster than searching thru 6 inches of manuals during the 1st few weeks of you new MB experience when you are familiarizing yourself with included features, under-explained features in the manual, etc...
Don't get so upset that someone has put you in his "ignore list" for he is not interested in you, and you will find no shortage here of people who WILL jump in and help you! Its a big community here, and just like any community real or virtual not every neighbor is a lifelong friend.
Down the road, you will still be able to see his posts, and as you become more familliar with your car, and may discover things, HE will not be notified of your new posts which may be buried deep within a thread...So who is the real loser in that deal...?
Don't feel hurt or insulted, come back often & ask what you want! There are a lot of great people here!
P.S. He put me on his ignore list months ago!
P.P.S. Update your profile with your "Location" so we know which geographical area you are in. These cars are different in every country in which they are sold.
Old Jun 14, 2004 | 07:31 PM
miroj's Avatar
If this is the home of the frustrated then I suppose it is the wrong place to ask questions about cars. This really is the most sarcastic forum I have come across for this type of car.
I dont plan on hanging around.
Old Jun 15, 2004 | 07:26 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
...there is a - I don't know - 10 page??? - thread about this in the W211 section which has been answered correctly after which the answering post was mocked at by the forum members in most need of an explanation...
Eventhough this might not be of much use and might not be apreciated by anyone...
The W211 default setting with which it comes from factory - the feature to choose between search by frequency or search by preset station is switched off in the instrument cluster (sorry Miro - wrong answer eventhough you used less words).
This setting - however - can be switched on with the help of stardiagnose after which the IC will come with an additional setting menu in which one can choose between preset or frequency search...BUT IT DOESN"T MAKE A SINGLE DIFFERENCE as the up/down button from the steering wheel will continue going through frequencies rather then going through preset stations which is the reason why this setting is switched off in default setting anyways.
it is a software glitch that hasn't been worked out yet
greetingz,
Old Jun 15, 2004 | 07:30 PM
scorchie's Avatar
I read on the internet that this works on very late production cars (say April and later).
YMMV.
-s-
Old Jun 15, 2004 | 07:39 PM
DWP's Avatar
DWP
'08 AM Vantage V8 - '03 E500
I also read on the Internet that a little boy with cancer named Craig Shergold wants to set the world record for get-well cards. Be that as it may be, if the no-presets "feature" is a software glitch that is corrected on the latest-production W211s, the same software fix should be available for installation on each and every W211, no?
Old Jun 15, 2004 | 07:46 PM
scorchie's Avatar
I am glad you saw my point in posting my source...
It SHOULD be. WILL be? Maybe. Under warranty? Haha.
-s-
Old Jun 15, 2004 | 08:43 PM
miroj's Avatar
... (sorry Miro - wrong answer eventhough you used less words).
There is no shame in being wrong. I would rather take a shot at the question than take a shot at the person asking.
A lot of this information is very specific to date of manufacture.
Old Jun 15, 2004 | 09:08 PM
Brav's Avatar
Give me a break, its not that big of a deal. Scorchie is right, but still, not that big of a deal. Wasnt a stupid coment, just explaining why he suggested a search - its been convered countless times. I'm not hear to be a smartass or unhelpful, just moving the forum along!
Here is one of the recent threds covering this topic, among many found in a 10 second search for "radio presets"
Old Jun 15, 2004 | 09:10 PM
Brav's Avatar
I was not being sarcastic, just straight forward in explanation for scorchie. Honestly this is one of the best forums around. Hang out on a BMW or P-car or Audi board and then tell me about sarcastic and useless.. I've been on them all.
Old Jun 15, 2004 | 10:47 PM
DavidNJ's Avatar
'05 E320 CDI;'04 S2k;'94 Supra TT;'10 QX56;'38 Buick;98 Port City Offset Late Model
Actually the Bimmerfest European Delivery forum is excellent (I keep asking for one hear but never get a reply) and there is a very good BMW E60 forum hosted at the University of Wisconsin.
Old Jun 15, 2004 | 10:52 PM
DavidNJ's Avatar
On our E39 BMW, one push goes to the next preset. If you hold it it seeks the next frequency. Up or down.
Old Jun 16, 2004 | 09:00 AM
jyg e500 maybe's Avatar
2000 528BMW 5sp
on e39 but not e-class
just another reason I said e-class radio is hard to use
Old Jun 16, 2004 | 09:42 AM
miroj's Avatar
I can only suggest that it takes more energy to fart around than it does to pull out the facts. For one thing is makes the facts look thinner and makes 1 page of information stretch over 3 pages.
Personally I judge a forum by how many part numbers and hard core facts it produces. Thank god for MBenzNL is what I think.
Personal opinion does not make cars go faster or better ....... so why spread attitude.
Old Jun 16, 2004 | 12:21 PM
Brav's Avatar
No attitude or animosity intended mate - happy motoring
