Transmission fault:p2767
But once a code has been pulled (see first post), I would always start with fixing this code because it's REAL. This requires a new conductor plate (around 80-100 bucks).
Everything else is just a GUESS.
Yes, it may be a good Idee to replace the TCC solenoid once the mechatronic unit is out and the conductor plate gets changed (I will do this too on my car this weekend due to lockup issues - YT video follows).
But is it necessary? Well, we don't know, because we don't know if/ when the solenoid was replaced before. I can't imagine a unit with lots of miles on it still running with the first set of solenoids. Is it the first unit? Do we know how many miles it ran?
NO!
So I would be thankful not getting bashed for correct advices.
And yes, I thought you are referring to code p2767 BECAUSE THAT'S THE TOPIC OF THIS THREAD.
Originally Posted by AUTOdidact
The "clunk" - when "letting off the gas", and only in sport mode - can come from ANYTHING (engine/ trans-mount, rubber flex plates...). This problem may or may not be related to the failure code.
NO!
NO!
A free app. Could it be an error
I appreciate this advice. Problem is I don't have a lift otherwise I don't think this would be to hard for someone with about 0 mechanic experience. Another question- this started when I got the car I had an MB guy look at it with star??? I mentioned to him the problems I experience he looked into the trans modules and came back with nothing. I currently don't have a check engine either this simply pulled from
