Inconsistent starting
This text goes with the pics submitted..
This goes with pics..SORRY..
I am so new and struggling with navigation on the site. hope i'm doing this right...Very recently purchased a 2003 E500 W211 and issues I'm having are what I believe is battery drainage or a short? it's been a nightmare.. it will start after i use a charger and place it under the hood at drivers side by fuses.. that access spot starts it up quick.. The reason I am not doing it from the main battery is because the trunk will not open.. With a full charge, key fob or switch on door will not open it. The manual key goes right in and turns all the way both directions but doesn't pop it.. I saw a video with clear tubes that somehow pump air through to pop trunk open. i'm thinking it may be an issue here. So as for starting, when i start it with battery charger and drive it like 80 miles or so, it will start for about 4 days.. if i go to start it and have to jump, and i do not make a long trip it will need to be jumped the next day..
*i have pulled both plug ins under driver and passenger seats that are electrics seat switches and was told they could be the problem draining as they go 24/7. i left them out for two days.. it still had the issue. plugged them back in..
*had aux. battery checked and its 12.86
*when accessed the trunk 2 mos. ago, replaced main battery
* a friend told me that he beleives the alternator is in great shape.. #still a mystery
*Codes appear off and on at random.. 1)consumer battery ?? switched off 2) ESP not available..see owners manual 3)all in red letters and key will not turn until i put on charger, says something about the brakes .omg, I don't remember. Maybe a message to do with SBC system???? 4) visit shop ..SOS phone (not connected and not in car, but always get the message..
With all that being said I discovered two alarming things 1) while battery charged and driving, i plugged a USB phone charger into both lighters front and back with an adapter. i looked at the phone and it was @ 19% and it showed charging flash off and on.. it went to 2% within 10 min. i found it strange.. didn't charge, but killed it!!
The second insane discovery while taking bottom back seats up to see about going into trunk, i saw first the carpet with broken window glass and started to vaccum it. lifted the carpet and I will show a series of pics of a gooey substance that I thought was chocolate syrup, but very thick and no smell.. I lifted other sear and found some there, but not as much.. this substance was covering certain electrical wires. I am so confused about this and hope it is familiar to someone.. So sorry for the long message, I really do apologize..thank you in advance.
This is behind driver seat with seat lifted and carpet lifted..
same, but closer up
glass pieces mixed in with this.. i removed it and soaked up this stuff.
carpet lifted to show rubber side on bottom of the carpet. it's a sticky liquid that is mysterious to me..
a view of it from above..
passenger back seat lifted , more glass on this side too..
lifted the carpet to show this rear seat under the carpet
Also a view of the back passenger seat from above..
Last edited by penny brown; Aug 20, 2019 at 07:43 AM. Reason: Text was supposed to submit before pics.
This is back seat behind driver side under seat and then carpet lifted..
Oily?
Runny? Like honey or tacky?
maybe its pepsi syrup from a long ago spill of soda or a sealant of some type.
