E-Class (W211) 2003-2009
Having trouble finding e320 4matic struts and axles!
Old Sep 7, 2019 | 01:40 PM
DoodoaXD's Avatar
2005 Mercedes E320 4 MATIC
Both my front axles and struts need replacing on my 2005 E320 4matic and the mechanic has bought THREE different struts that were listed online to fit my car, but he told me none of them fit.
He says that the only ones that can fit are ones for an ML320, or the genuine Mercedes Benz parts that cost a fortune. Is this true?
can someone please link me some parts that should fit? Thank you.
Old Sep 7, 2019 | 01:45 PM
tjts1's Avatar
C320
Your mechanic is incompetent find a different mechanic.
Old Sep 7, 2019 | 03:40 PM
konigstiger's Avatar
'71 Pinto
Front struts cross reference current OEM part #s left 2113237900, right 2113238000 to shop aftermarket. See attachments for suspension & axle part lists.
File Type: pdf
File Type: pdf
Old Sep 8, 2019 | 01:09 AM
cetialpha5's Avatar
I just went through this on my car. Rockauto sells two left cv axles, one is new and the other is a reman. If you get a replacement axle, try the reman one. I tried the new one and it created a vibration. I just got the boot kit from MB and replaced the boot on the original axle and replaced it. The boot kit is less than $40. For the right, rockauto doesn't carry it, but there are some aftermarket ones on eBay. Not sure if any of them are any good though and if they're new, you might run into the same vibration problem I had.
What's a good spring compressor to use on the struts?
Old Sep 8, 2019 | 08:29 AM
ot1's Avatar
ot1
2006 E320 CDI
What is the country of manufacture on the new one that caused a vibration?
Old Sep 8, 2019 | 01:23 PM
rodneypierce's Avatar
2009 e550 4Matic
More than likely China. As most "new" axles are these days. At least ones other than genuine MB.
Old Sep 8, 2019 | 07:43 PM
cetialpha5's Avatar
Who knows, it was a Cardone which rockauto stocks. I figured a new one should be the same, but I guessed wrong. The reman one is actually more than a new one and also has a core charge. But that's probably the way to go.
Old Sep 10, 2019 | 02:19 PM
DoodoaXD's Avatar
I found this on eBay, not sure if I should go ahead with a used part though. What do you think?
https://www.ebay.com/itm/04-05-Merce...MAAOSwy7xczGaw
Old Sep 10, 2019 | 02:48 PM
cetialpha5's Avatar
Technically as long as the boots are intact the axle should last forever. Once the boot rips and the grease leaks out, then the axle is toast. I'd save the old axle just in case it can be rebuilt with just a new boot kit. I just happened to notice mine was ripped and it wasn't making any noise yet so it was ok to just throw on the boot kit.
