Torque Convertor Clutch acts funny when cold
The first mile or 2 of my drive every morning the TCC seems like it will engage and then disengage continually, almost like it is slipping, but it keeps grabbing. Once I go about 2 miles it stops and is fine for the rest of the day. It seems to be more prominent at low and mid accelerator positions, and not as bad at higher pedal positions.
What should I start checking?
Can STAR do a recording of this so I can have a log? Its hard to review the data afterward without being able to datalog it.
I did a TCC Adaption on the car. The CDI has lockup in all gears and this procedure is for the 722.6 with a TCC that locks up in all gears. See the attachment for the procedure.
I am so tempted to change the transmission fluid and take my chances....
Your thoughts?
I ordered a transmission dipstick from Amazon and should be receiving it in a few days. When I check it, the result will be one of 3 things. First, the transmission is low on fluid. I will just fill it up. Second, the transmission fluid level will be at the right amount, but the fluid will either be dark or brown. If that is the case I will have the fluid changed. Third, The fluid is at the right level and looks clean or almost clean....I think at that point I will have to have it diagnosed and get an estimate on the repair and decide if it is worth fixing or not. I only paid $3200 for the car, I really can't see paying close to that for a transmission repair.
My question is this, my mechanic who I have had for several years is reliable, affordable and honest. He said that if I have the transmission fluid changed in my car, that it may not run right. He referred me over to his brother who owns a performance transmission shop. His brother told me the same thing. I have never heard of this happening to a transmission just by changing the fluid. Does anyone have any feedback on this?
Either way, if I do find out the transmission fluid is dark or black, I will more than likely have a Certified MB repair shop do the fluid change or maybe even take it to the dealer for that....
I had submitted a reply on this thread several days ago and it does not show on here....not sure what happened. I did not want to start a new thread seeing that the symptoms of the car in this thread are identical to mine....
The same “slippy” “hiccupy” shift from 1 - 2, and 2 - 3 at low revs. Always goes away within 1/2 mile. When engine and transmission are warm, no problem. Because it is always a matter of temperature, I suspect minor misfire and electric conduction in coils that are 15 years old and have 245,500
ill keep you posted here.
