E-Class (W211) 2003-2009
Alternator/Voltage Regulator Fault Diagnosis
Old Oct 25, 2019 | 12:44 PM
c_c230k's Avatar
1999 C230K
So replaced the voltage regulator on my W211. (2007 E350-PZEV; 194K Miles) about two weeks ago. Easy fix and old VR was definitely at fault with the contacts extending to the pony they were falling out of the plastic. I’ll add a pic if I can find the old part.
Yesterday, at the same time my brake light switch popped out of its seating causing “ESP inoperable visit workshop “ message and brake lights to stay illuminated, I got a red-battery warning.
After reseating the brake switch, ESP message went away, but battery warning remains.
From the dash- engine off- 11.4V. When running the voltage drops but stabilized around 11.2. Same as with bad VR.
Alternator, starter fuse block and battery connections verified intact and tight.
Is is there a bench test I can put on the VR(regulator)?
I’m hoping it’s merely a bad part I can replace under lifetime warranty from fcpeuro. Otherwise it’s a new $300 alternator
i remember reading somwhere these alternator’s output is computer controlled. Is it possible a faulty module or relay is causing no-charge condition?
Next: pulling alternator off car for any
Old Oct 25, 2019 | 02:00 PM
Agent-A01's Avatar
05 W211 E500, 03 C215 CL55 AMG
Sounds like a bad diode in the alternator.
Highly doubt a new bosch VR is failing.
There is a relay that switches charging on/off for SBC equipped cars but yours does not have that.
Corroded Driver SAM can cause no charge but unlikely as well.
Old Oct 26, 2019 | 02:20 AM
cetialpha5's Avatar
I would get the alternator from Autozone, it's a rebuilt Bosch and also has the same lifetime warranty that FCPeuro has, but you don't have to mail it to them, just go to your local store. With the 20% discount codes found on retailmenot and even on their website, it's under $200 for the rebuilt one. I don't think it makes sense to replace the regular on a post face lift car as it takes as much trouble to replace the alternator. It was easier on the older models. The older models also had a battery control module, but I don't believe yours does. Also if your battery is weak, don't let the alternator charge it up, put it on a charger. If you don't have one, most auto parts stores will charge it up for free.
Old Oct 27, 2019 | 03:36 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
195K miles? Your alternator owes you nothing. Replace it.
Just my 2c.
Old Oct 28, 2019 | 12:12 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
So new VR did not fix the charging warning?
Brushes are the only wearable on alternators, but old rings might need cleaning and diodes can burn occasionally,.
I remember most of automotive places will do free alternator test for you.
I had bad experience with such testing, but that's a start.
I still would remove new VR and inspect the rings.
New VR are made in India?
Old Oct 28, 2019 | 01:18 PM
ps2cho's Avatar
E
thanks for that info - my alternator is whining and need to replace it (145k). Is the autozone duralast actually a Bosch reman or could it be a Chinese random reman? Not interested in the later...
FCP’s Bosch reman is $100+ more than autozone hence some skepticism
Old Oct 28, 2019 | 01:27 PM
cetialpha5's Avatar
Looked pretty much the same as the one I took out only newer and cleaner. Got it last year and it's still working fine. It was listed for $215 when I got mine, price went up $13 in a year. After coupon code mine was $185.
Old Oct 28, 2019 | 01:32 PM
ps2cho's Avatar
E
great thanks sounds like this is the cheapest easiest route for me.
although my alternator still puts out 13.5v+ the whining concerns me as it sounds like a supercharger so time to go I think.
Sorry to thread jack but figured my Q also ties so OP may go down same route.
Old Oct 28, 2019 | 01:58 PM
cetialpha5's Avatar
Also had it shipped to me. They had crazy shipping, ordered it at around 6pm in the evening and they ended up shipping it at 9pm and I had it the next day. Mine might have been making noise briefly too, it was just burned up one day and I had the battery low warning come on so I knew it was probably bearings that were probably also shot in addition to voltage regulator.
Old Oct 29, 2019 | 12:15 PM
c_c230k's Avatar
1999 C230K
Just my 2c.
My W202 has 427K miles on original alternator. Replaced VR at around 278K and it still puts out a reliable 14.1V when running. That’s why I suspect bad part.
Will pull alternator this weekend to replace.
After VR replacement the vehicle ran great and charged at 14.1 for 2 weeks/350 miles.
Is there a bench test for VR or do MB mechanics just swap and see if it works...doesn’t sound like a good German procedure.
Thanks!
Old Oct 29, 2019 | 01:12 PM
kajtek1's Avatar
MB dealers "don't fo VR" that's why each visit to them runs into 4-digit$$$
