E-Class (W211) 2003-2009
RWD W211 Daily Driver In Winter
Old Feb 12, 2020 | 11:58 AM
AeonTheTerrible's Avatar
W211 E500
Hi all, I drive a rear wheel drive w211 (e500) specifically and am planning to move to a climate with real winters in about a year. Is a properly equipped w211 going to be okay in winter... Given I use winter tyres starting at the first snowfall and weights in the boot? Really don’t want to part with this car. Currently I am riding at stock height... would comfort suspension and the raising mechanism give sufficient ground clearance?
I’m looking at moving to Eastern Washington/Idaho area for anyone curious, and they get quite a bit of snow. The roads around the places I'm looking at are pretty well maintained and plowed.
Old Feb 12, 2020 | 02:02 PM
CastorTroy's Avatar
2014 E550
you will be fine. it certainly isn't as pleasant as an awd, but i have had no problems getting around with winter tires on my e550 rwd, in bozeman mt
Old Feb 12, 2020 | 02:40 PM
cowboyt's Avatar
Mercedes-Benz S430, S500, S600, and E320 CDI
Yep. As long as you use snow tires when it's snowy, you should be fine. Eastern Washington is pretty flat, so just drive like the ol' folks taught us, i. e. pretend there's an egg between your foot and the pedals. Our E320 CDI, also RWD, does relatively fine in our area in the snow even with all-season tires.
Old Feb 12, 2020 | 03:15 PM
Agent-A01's Avatar
05 W211 E500, 03 C215 CL55 AMG
With the right tires it will do great in the snow.
No need for weights in the back
Old Feb 12, 2020 | 11:15 PM
tjts1's Avatar
C320
Get the narrow snow tires on dedicated winter wheels. 215/55R16 is a good size for 211 snow tires.
Old Feb 13, 2020 | 12:25 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
I live in Eastern Idaho, right up against the Grand Teton range. Rear wheel drive is how cars are meant to be driven in the snow. Hakkapelitta R2 tires turn winter into summer. Be sure to turn off the ESP every now and then so you don't forget how the car works without a nanny watching out for your heavy right foot.
Old Feb 13, 2020 | 01:02 AM
rodneypierce's Avatar
2009 e550 4Matic
I live in Iowa and would likely be fine with a RWD and snow tires. Ill say though, having 4matic with our winters sure is nice!
Old Feb 13, 2020 | 11:33 AM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Of course, You'll be just fine. When the snowflake meets that three pointed star they melt!
