2004 E500 W211.70 Rear Shocks Replacement
Bilstein has 2 shocks listed, 19-0500027 Which cross references to MB OE 211-326-01-100, and 20-101893 that references OE 211-326-02-800 , both fit w211.70 base with airmatic code 489. Arnott has 2 different models, one is new and one is rebuilt, SK-3012 and SK-3197, both reverence the two MB OE numbers above. My question is as follows :
1- Are there different Airmatic Systems for the same year model with code 489?
2- What is the difference between the two shocks other than one is monotube and the other is dual tube.
I accidenttly bought the 19-0500027 because when I searched for my car model and year one site listed it as OEM fit but later when looking for install instruction on this forum somebody pointed to the two different part numbers but so far I cannot find the technical reason other than the chassis number to justify the big price difference between the two shocks.
P.S : Mercedes Part Center list them both for the 2004 W211.70 but one is Graz built. Anybody knows what that means?
https://www.mbpartscenter.com/search...h_str=211-326-
TIA
Do you have ads? If so, I believe the Arnott shocks don’t support this feature, but rather use a resistor or some other electronic means of fooling the car into thinking this feature is still present.
The other difference might be whether or not you have 4matic vs rwd. I’m not sure if there are different shocks for that. The only other thing that comes to mind would be rear load leveling vs full air suspension. Not sure if that is a factor or not.
I believe for my car at least, the Bilstein 20-101983 are correct for full air suspension with 4matic and ads. They’re about $272 a piece on rockauto.
Bilstein has a website where you can input your vehicle, and see the correct parts. The only Arnott parts I used (or would consider) are the rear air springs, and maybe the compressor if need be. I did use the Arnott rear air springs when I replaced mine. I believe Bilstein is the oem supplier for all the shocks/struts/springs.
I already bought the 19- shock for $176 bucks and it is pain to return it and my question is what happens if I use it on my car? If it is a performance issue ( mono vs dual tube) I don't care since this is my second car and I only use it for commuting. Am I gonna have error codes? So far nobody is able to give me good answer. I called several vendors and the persons answering the phone all they can do is punch numbers and give me a non-technical answer. I even called Bilstein tech support and they were no help.
I can’t speak to the results of using the shocks you already purchased, but I wouldn’t use them.
https://www.mbpartscenter.com/oem-pa...IFJlc3VsdHM%3D
Shock Absorber - Mercedes-Benz (211-326-01-00)
2004 Mercedes-Benz E 320 4Matic®, Base 3.2L V6 -Gas2004 Mercedes-Benz E 500 4Matic®, Base 5.0L V8 - Gas
2004 Mercedes-Benz E 55 AMG® Base 5.5L V8 - Gas
P.S: the specs on the -2800 says "Adjustable" while the -0100 not. What does that mean?
