My CDI Performance Build With Pics Blue Top Solenoids and other stuff
Subscribe
Apr 25, 2020 | 03:40 PM
Hello All
I have made many upgrades
Current Power 240 HP 420 TQ
Engine and TUNE
1. Oil Separator NEW . $65
2. New Timing Chain Tension Bolt . $100
3. Carllson C Tronic Tune Box . $300
Transmission ,, 04/25/2020 E55 Stock valve body with new conductor plate with SLR Blue top solenoids SET. $230 For Valve body and solenoids
Brakes .
Ceramic Brakes and Rotors $450
Exhaust : Straight Pipe Exhaust
Transmission: I have as of today a E55 valve body and I have put in OEM solenoids from and SLR with a DORMAN factory plate and SLR SOLENOIDS BLUE TOPS AND ALL >4/25/2020
Reply 2
Apr 26, 2020 | 06:11 PM
Update the valve body is going in WED . Finally got it scheduled.
Reply 1
Apr 29, 2020 | 06:10 PM
Reply 0
Apr 29, 2020 | 06:18 PM
WOW . Night and day difference no more transmission confusion. The shifts are clear and almost instant . It took all the slip/ LAG TIME between 1-2 out Under full load .
The down shifts were hard at first but the computer re adapted it has smoothed out ...C is still smooth . now when you have to pass just a little push and your passing .
The car feels like its always in gear and is clear through the power band much better . Very worth the $400 upgrade I feel a valve body would not be needed at this power level ....instead of $1000 for the same thing .
THIS ALSO has eliminated a giant lag when pulling onto the road.
Reply 0
May 1, 2020 | 06:08 PM
EXCITING NEW UPDATE .... SOLO MOTORSPORTS IN ATL ..... Gonna do a BASE DYNO TUNE WED.......... After that doing a tune CUSTOM Dyno tune $600. I will be selling this Carrlson Box if anyone is interested good for a 40 HP gain and 60 TQ gain as advertised .
Reply 0
May 10, 2020 | 05:36 PM
i'm curious to know more about your transmission work. did you just install the e55 valve body with slr blue tops and everything played together nicely or was there some resetting of the tcu required? i've been looking into the blue tops for my cdi(other than the sluggish tranny i absolutely love it) that tends to flare when cold on the 3-4 upshift. i changed fluid, added the sonnax overlap sleeve kit and a transgo 722.6a shift kit, seeing no improvement. then i disassembled and cleaned the valve body entirely(solenoids included), replaced the conductor plate, with another fluid change and still have the cold 3-4 flare. it's never thrown an error code, but shifting just seems... off. nowhere on the entire internet can i find which valve bodies work in which trannies with which tcu's controlling them and what the differences between them are. everything i've learned points my difficulty to the tcu's programming or the valve body's operation. i can't find programming for the tcu in an e320, but if a valve body swap would do the trick, or just the blue tops?
Reply 1
Jul 17, 2020 | 07:28 AM
are these the selenoids that you have installed.
https://www.autohausaz.com/pn/148098...iABEgJPafD_BwE
Reply 0
Oct 18, 2024 | 11:02 AM
hi oliver
could you put the parts number of the bluetop solenoid please ?
Reply 0
Explore
Subscribe
Currently Active Users (1)
