Help! E500 rear wheels won't turn - slight play.
My thinking is that maybe the parking break had seized but before diving into different things I would love to get anyone's input as to what to check next. At this time I think I am going to take the brakes off to ensure they are not simply seized on.
Could this be a result of a broken/damanged flex disc?
Thanks for anyone's input... it is greatly appreciated.
This may be a dumb question but it would really help me narrow things down (to the brakes specifically..
While examining things further, I've noticed that the wheel with a quarter turn of play is the right rear wheel only, the left side seems stuck.
If the brakes were engaged on the left side (say frozen due to rust or a stuck caliper, whatever the reason) what movement should the right side be displaying.. for instance, would it make sense in that scenario that the right side may only be able to move 1/8 to 1/4 rotation and back?
Also, While having someone turn the right wheel I can see shaft going to the engine turning so I am hopeful that its not the differential that failed - would love anyone's input on my question.
Basically, if the left rear wheel has the brake engaged, what movement, if any, is normal on the right rear wheel?
Thank you in advance for everyone's input and comments... This is a great community and I look forward to being able to give back. Thanks again!
Mark,.
Mark,.
I suspect that no matter what I am going to have to free up the left side, in the mean time if anyone can describe what the right side should be doing in this sort of scenario it would be quite helpful
Regardless thanks for everyone's input and ideas.
