E-Class (W211) 2003-2009
2004 E320 w/ 45k miles. Thoughts?
Old 11-04-2020, 09:24 PM
Belmin07's Avatar
13 c63 AMG
Hi all,
I am looking to purchase a 2004 E320 with 45k miles. It has been well maintained, clear carfax, always garage kept and never seen salt. Are these cars reliable? Is $7000 a fair price for this type of car? It has a couple scratches on the body as shown on the pics below but the underneath of the car and interior looks brand new. Thanks for your feedback!
Old 11-04-2020, 10:22 PM
F1Fan's Avatar
That car has a lot of life left in it. I would pick it up, perhaps at a lower price. Just check to see if it is a salvage or flood title. Cars at that age with so few miles are always a find, but just check to be sure.
A few things:
- Looks like it does not have Airmatic, which is probably a good thing. Replacing the air springs will probably set you back at least $1000 on parts alone and the Airmatic will leak sooner or later. Looks like standard shocks.
- Engine is most likely M112 v6. Very reliable. I think the rubber gaskets will probably need replacing if you start to see oil leaks up top. Breather hose will probably become petrified rock hard, but these are easy to replace.
- Transmission also very reliable, as long as fluids are replaced on schedule. That car probably has never had it replaced. If I were to buy that car, I would do a drain and fill.
- There was a recall for the radiator leaking, I believe for 2003 or 2004 models. You should look this up as it may affect this car.
- SBC Brakes, since this is now covered under a 25 year warranty, I would not worry about it.
While not Toyota reliable, it is still a very reliable car. The M112/M113 engines along with the 722.6 5-speed transmissions were very reliable. If you are a bit handy, doing a few simple maintenance items can keep this car going for many many years and miles.
The following 2 users liked this post by F1Fan:
2MERKS (11-05-2020), Belmin07 (11-04-2020)
Old 11-04-2020, 10:48 PM
Belmin07's Avatar
13 c63 AMG
A few things:
Thank you for such a great response! Much appreciated. No aromatic. What do you think is a good price for this car? I tried to get him down to 6500 after the inspection found those scratches but he won’t budge. Did not know SBC was covered under a 25 year warranty. Is that for the orginal owners only or for anyone whom owns the car?
Old 11-05-2020, 01:42 AM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
If you like the car, than 500 bucks won't make a difference.
I agree with what was already said. I used to own a 2003 E320 and it was very reliable. I thought I had low miles on it with 96K, when I sold it in 2018.
SBC warranty should be for the car, regardless of how many owners.
Good luck, keep us posted.
Old 11-05-2020, 04:00 AM
Lubo2018's Avatar
MB E 320 CDI 4matic
Thumbs up
the only thing to worry about is only SBC. If it is under warranty, there is nothing left to worry. Good car and good luck
Old 11-05-2020, 04:09 AM
tjts1's Avatar
C320
Buy it as is at $7k if you plan to keep it for a while. SBC is covered by an unlimited mileage 25 year warranty that extends to new owner. Fuel tank is also covered by a 15 year unlimited mileage warranty. It leaks from the top when it's full. No drip on ground only fuel smell. It only happens when completely full.
04-05 gas E320 is by far the most reliable easiest to maintain w211 with the lowest cost of ownership. Mine has 184k miles on a steady diet of 87 octane and it's still good as new.
Old 11-05-2020, 07:28 AM
2MERKS's Avatar
'99 CLK/05 E500 WAG
In the center console see if the dongle is present. Guessing owner is using the miles as weight to get 7K. Those scratches can be buffed out, and a steady hand for touch up paint would be good idea to purchase.
GL
2MERKS
Old 11-05-2020, 09:10 AM
S70Houston's Avatar
^^^ THIS!!!!
Old 11-05-2020, 09:56 AM
Overheated's Avatar
1998 E320 Wagon, 2003 W211 E500, 2003 W211 E500, 1999 W210 E55 AMG
^^^ THIS!!!!
If you want it, buy it. If it's well maintained as you say, it's a find. Go to the dealer with the VIN and get the service history. They may or may not give it to you. If possible, get a pre-purchase inspection.
I just picked up an '03 E500 with 172K. Lots of records, body and chassis in great shape, runs well. At 45K, to be cautious, change all fluids...engine oil & filter, trans fluid and filter, coolant, brake fluid. Rubber and plastic that old will start to degenerate, so anticipate replacements. Read the plugs, oil, and coolant.
In '05 my first E500 had 30K, cost me $30K. It's a great car.
Old 11-05-2020, 10:31 AM
2MERKS's Avatar
'99 CLK/05 E500 WAG
^^^ THIS!!!!
Please fill me in on the lingo?
2MERKS
Old 11-05-2020, 10:39 AM
S70Houston's Avatar
2MERKS
I agree with the following: "Those scratches can be buffed out, and a steady hand for touch up paint would be good idea to purchase."
So, arrows ^^^ pointing up to the quote saying "THIS", means that I agree with the statement.
All Good?
Old 11-05-2020, 11:34 AM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
Thats a crazy low mileage car. I guess that is why he is asking 7000. So let go thru this.
V6 m113 should go 250 to 300k miles
Trans is bullletproof
No Airmatic.
SBC covered for 25years.
I think this would be the most reliable mercedes you can get.
Here is what you want to budget for. since it is an aging car.
Engine Mount. & Trans mount
front suspension ball joint and track arms
Brakes.
Fluid change. Engine, Trans.
Spark plugs and wires.
Crank position sensor.
enjoy.... for next 15 years.
Lubo2018 (11-06-2020)
Old 11-05-2020, 11:45 AM
S70Houston's Avatar
No Airmatic.
Brakes.
100% agree!
Just for 2MERKS - "^^^ THIS!"
Old 11-05-2020, 05:19 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
100% agree!
I appreciate that. I had no idea about the meaning. All good here.
R,
2MERKS
Old 11-05-2020, 05:21 PM
S70Houston's Avatar
I appreciate that. I had no idea the meaning. All good here.
R,
2MERKS
2MERKS (11-05-2020)
Old 11-05-2020, 05:29 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
absolutely!
Old 11-05-2020, 08:31 PM
F1Fan's Avatar
fkong777 has good points on what to look out for. I would add that on my E320, the SBC loves rear brake pads. It tends to use up rear brake pads more often than the front. I'm ok with that, just need to be aware of it. But FCPEuro's lifetime warranty takes care of that. As mentioned earlier, engine mounts. Car loves engine mounts. Those fluid fill mounts really make a huge difference.
Because the fuel leak recall window has now passed the 15 year warranty on a 2004 E320, here are the parts that were replaced on my E320. Just for reference in case you smell fuel.
Fuel Pump, part #: 2114704194
Fuel Pump hose bracket, part #: 2114710141
Fuel Sender seal, part #: 2114710579
You can price out the parts listed above.
Old 11-06-2020, 08:56 PM
S70Houston's Avatar
Well, any news here?
After all this favorable input, did you buy?
Old 11-17-2020, 03:52 PM
Legodude's Avatar
2006 e320
Early cars had hydraulic bushing which fail and the radiator which destroyed the trans. If they have been addressed. Sbc is your only big ticket item. W211s are 👍 m112/113s are great.
Old 11-17-2020, 04:40 PM
cetialpha5's Avatar
Received 1,506 Likes on 1,177 Posts
SBC has the 25 year warranty in the US so it's still covered. However there is a 15 year extended warranty on the fuel tank for W211 and would have expired by now.
Old 01-22-2021, 05:15 PM
ChubbyFlyers's Avatar
E320
Gas Tank / I have that problem where I smell gas and seen the top is leaking
am I still covered on my 03 w211. I get gas leaking from the top when I fill the gas. I can see the gas come out. Top where all the hoses meet up.
Old 01-22-2021, 05:26 PM
cetialpha5's Avatar
Well 15 years ago would make it January 2006. So unless the car sat on the lot and didn't get registered til that date, your 2003 probably has an expired warranty on the fuel tank. It seems it's the gasket on top of the tank. Some people have just fixed the leak instead of replacing the entire tank like MB does. You'd have to search the old threads for exact details.
Old 01-23-2021, 06:15 PM
vagt6's Avatar
2004 E320; 2012 SLK 350; 1973 MGB MK III roadster.
BE sure to check the air suspension. It's time to replace it if it's original. Not cheap to do.
2MERKS (01-23-2021)
Quick Reply: 2004 E320 w/ 45k miles. Thoughts?
