rear suspension loses air but not the front
So, my rear air has been leaking overnight, but it only leaks when the car is in normal mode (not raised). If i leave the car in HIGH mode, the rear will not leak. Ive tried this multiple times now and the result has been the same. Tried to search for leaks on the rear lines by spray soapy water on critical locations, rear valve block, bag lines, and valve block on the front but nothing obvious pops out that its a common leak. Wondering if anyone else has had this issue when put in this condition.
Im more afraid to drive on the freeway since the car will automatically lower when at a certain speed.
Soapy water 3 or 4 times and at varying heights. I've changed all of mine and each time the leak was only obvious after multiple attempts and a bit of time. Do all the lines as well.
Also check the height sensors. They are known to corrode and stop working.
