Black Death
Anyone ever run into this issue? I have half a mind to just drive it into the ground, since I only paid 9k; but I like the idea of this engine lasting forever.
Black death isn't too hard to deal with, and is a well documented issue on this forum.
This post has me thinking I need to list my '05 CDI with 172,000 miles for $10K. No black death, fresh ball joints and alignment, considerably quicker than my '13 E350.
Are you referring to a leaky fuel injector seal? These cause deisel fuel to pump up through the the injector in between the cams. The fuel turns to a black goo. The cost might be the labor of cleaning out the mess. Not a difficult job but time consuming.
Pull it all apart. Pry the injectors out. Plug the injector holes with a paper towel. Scrape and clean all of the black goo out.
Maybe bore the seal. Replace them two dollar copper seal. Use the $25 special white paste. Reassemble. Done.
Not intense. Not easy though. Labor intensive.
Peter
Unless the black goo has frozen it into the hole. That is why I warmed up the engine to soften the goo prior to using some small lady slippers (a kind of pry bar) to pry them out. The injectors are expensive so you don’t want to destroy them.
Ha! I wonder if you loosened the clamp and then cranked the engine a few times, if the pressure of that super high compression diesel would push them out to where you could pull them out easily.
Peter
Is that the neighbor down the street or just next door?
Forget the fancy tools. This I’ve got to see for myself. Marvelous!
Peter
BTW, it has been a while for me. I assume the stretch bolt is the one that holds the clamp down that holds the injector in. I wouldn’t expect that to come loose nor strip, (but I do all of my own work so I know there are no shortcuts). I would be more concerned that the bore needed counter boring to make a clean seat for the copper seal. Once the seal is lost, you get gas erosion in the aluminum of the head and you need to assure a good seal there.
There is also the “Special Grease” that I have no clue what it does but has that descriptive name and cost a bunch per teaspoon. For all of the effort, I would also recommend that grease.
Good luck,
Peter
