2004 Mercedes E320 4Matic Vibration wont go away
.i recently purchased a 2004 Mercedes E320 4matic with 89000km on it there was a lot of vibrations going on in the car so the first thing i did was go to the forums since this is the first Mercedes i purchase haha.
i gathered a lot of info before making this post i changed my harmonic balancer it was due to be changed, vibrations got better i then changed my engine mounts because the old owner did not know what these were completely finished made a huge difference in the vibration after changing them out, but even with that i still notice a vibration in the car especially when the car
is in Drive or reverse and i don't push the gas and when i turn on the A/C its even worse.
I then decided to change the spark plugs because i noticed there is a wobble in the engine like there's a miss fire. It was better but still vibrations in the car, i also disconnected the coils 1 at a time and re pluged them while car was running to see if there was a coil that was faulty, they seem to be working properly.
i then decided to change my belt tensioner since there was a noise coming from it fixed that issue lol. my transmission mount seems to be still ok after 89000km
one thing i noticed was my harmonic balancer still wobbles a tiny bit don't know if that's fine.
please i need help i don't know what else to do but to change the injections on the car and even with that i don't think its gonna fix the vibrations issue. i hope one of you guys can help me out with this.
When you say harmonic balancer, do you mean the main external crankshaft pulley?
Have you replaced the internal balancer assembly? This is needed for 90 degree V6 engines such as yours. They fail over time.
With a car nearing 20 years old, it’s time to replace anything rubber. If it’s rubber and it’s not 5 years old or newer, replace it.
I have a 2004 E320 and was experiencing similar vibration at idle and low RPMs, seemed worse when the engine was cold (see this thread). I chased this by replacing plugs and wires, injector cleaner, etc., thinking there was something wrong in the engine. I noticed that I could feel my vibration inside the car and at the steering wheel, when it was in drive/reverse and at low RPMs which I thought was more like a bad plug or wire/coil (no codes should have been a clue that there were no misfires or other issues, etc). When I looked at the engine itself when idling, it really wasn't shaking/vibrating and was actually pretty smooth. However, if motor and trans mounts are bad, you are going to feel vibrations it in the car and likely at the steering wheel.
Replacing the motor mounts and transmission mount with quality Lemforder (OEM) mounts, made it drive like a different car. I realize that the OP indicates motor mounts had been replaced, but I would look at the motor mounts and transmission mounts again, confirm they were a good quality brand (I would only use Lemforder, or maybe Corteco (I them Mercedes from Dealer are Lemforder) - I shopped around and bought from FCP Euro (no affiliation)) and I would confirm that transmission mount was changed as well (again with Lemforder or Corteco).
Just my opinion, could be something totally different...
Lee
Yes, a 90 degree V6. Unless it's a slant 3. I don't think MB made a slant 3. Did they?
Balancer assembly is a candidate. Vibration while idling or revving in neutral.
Harmonic balancer is the main crankshaft pulley. Not the same as a balancer assembly.
In my opinion the OP needs to make sure he has Lemforder engine mounts. All other substitutes will vibrate.
i was debating on the corteco and boge mounts and finally went with boge since people were point more for those then the corteco mounts.
if i would show you the mounts before lol you guys would freak out the original owner didn't know what moto mounts were. It was an old man.
im gonna try replacing my transmission mount to see if that might be the issue but my mecanic told me its still good but it hasent been changed since the car has been built in 2004.
when looking at the engine when on it looks like a small vibration and it looks like a misfire but i don't have any engine codes. im really at a a loss tbh.
also i live in canada does anyone know here i can get the transmission mount for my car? autopartsway.ca dont have it on their site, also how does it look like?
Buy one ignition coil and swap it in sequentially in each cylinder to see if the vibration goes away.
Lee
