E-Class (W211) 2003-2009
w211 E200CDI 2007,Drive axle out of differential housing
Old Jul 6, 2021 | 03:31 PM
Ryan Cooper's Avatar
Mercedes Benz W211 E200 CDI 2007 Sedan
anyone have a walkthroug on how to get the axle out off the housing, do i have to open the diff or is here a C-clip on the outside??
Old Jul 6, 2021 | 08:18 PM
ptkacik's Avatar
2005 E320 CDI, 2015 GLA 250
As I recall when I did the LR differential seal on my ‘05 CDI, it was a spring clip. I just had to pull hard and the axle popped out. Maybe a big screw driver. But not enough to damage the metal shield over the lip seal.
I think,😬
Peter
Old Jul 6, 2021 | 08:30 PM
cetialpha5's Avatar
You mean the CV joint out? You put a 3 inch muffler clamp on the axle and then you can use that point to tap it out.
Old Jul 7, 2021 | 02:50 PM
thanks, that helped alot
Old Jul 7, 2021 | 02:52 PM
Yeah the CV joint on the diffirential side, looks like the seal on the left has come out off the diffriential for some reason
Old Jul 7, 2021 | 05:46 PM
konigstiger's Avatar
'71 Pinto
See attachments.
Old Jul 8, 2021 | 12:34 PM
Is it the same in th rear as in the front? Thank you
Old Jul 8, 2021 | 12:50 PM
'71 Pinto
I may have misunderstood previous attachments are 4matic, see attachment for RWD rear differential.
File Type: pdf
Old Jul 8, 2021 | 03:19 PM
Thanks, just what i needed, save my day
