E-Class (W211) 2003-2009
Non air suspension help..
Old Oct 26, 2021 | 08:21 PM
baris41's Avatar
w211 e350 4MATIC
Non air suspension help.. SOLVED
Hi guys,
Today car had developed a new problem, it was fine when i parked it at yesterday night. Car is e350 4matic non-air suspension. As you can see in the pictures, left rear shock seems shut. Do you think is that the reason or might it be something else? If it is, OEM shocks are really expensive so, i'm willing to go with aftermarket. So i'll have couple of questions;
1. Is this shock absorber same as A2113262800 which is the oem shock?
Rear Shock Absorber - 19-235219 by BILSTEIN on PartsAvatar.ca
Rear Shock Absorber by BILSTEIN 19-235219
partsavatar.ca
2. If they are not the same, should i be changing rears, or all 4 of them?
3. Looks like OEM suspension has some kind of sensor in the pictures, would i need that?
Old Oct 26, 2021 | 08:56 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
If you post your VIN it would be clear which shock you need.
If your car has standard suspension, non airmatics, the height is controlled by the coil spring as far as I know. Shocks are not supposed to sustain weight, only to damp motion unless fully compressed .
Old Oct 26, 2021 | 09:52 PM
baris41's Avatar
w211 e350 4MATIC
Doesn't that mean shock is dead? Might that be something else?
VIN: WDBUF87X67X216730
Old Oct 26, 2021 | 10:48 PM
JCM_MB's Avatar
Here is the datacard for your vehicle.
From what I understand, it is a 4matic with standard suspension, code 494 US version.
If you look at your rear suspension you should see spring coils. Here is a link to the mbepc listing the parts for your suspension
http://mbepc.net/1/fg/e/65h/211087/0/32/154#gsc.tab=0
Old Oct 26, 2021 | 11:01 PM
tjts1's Avatar
C320
Shock absorbers don't dictate ride height. You have a broken coil spring.
Old Oct 27, 2021 | 10:48 AM
konigstiger's Avatar
'71 Pinto
Rear spring is part # 2113240204 (color marking: 2 x blue/2 x yellow), shock shop OE part # 2113261500 should also pull compatible aftermarket.
File Type: pdf
Old Oct 27, 2021 | 11:45 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
I'll second the broken spring. Likely in the bottom mounting surface. Do both sides then get an alignment.
I just replaced all 4 springs in my '05- 3 broken over the summer. First time I've ever had to replace springs in any car/truck I've owned. I think they make them out of potato chips.
Old Oct 27, 2021 | 07:59 PM
baris41's Avatar
w211 e350 4MATIC
Exactly, i never owned a car broke its springs over night. And yes, spring was broken. I bought only one just because it's urgent. I'll order h&r all over.
