E550 FANS Need some advice!
Im looking at a 2007 E550 this weekend with 120k miles , good service history. I already own a 2004 E500 so I am familiar with this chassis. I do know it will need rear bags at some point , no big deal did my own on the 500. And apparently it has a clunk at low speeds which i was told was a u joint , this makes me a little leary ..if its a u joint or Flex disc or carrier bearing no big deal but if its a transmission issue then obviously a big deal.. The owner says it is fine when driving and only a issues at low speeds ...Im bringing my scanner but I need the 550 experts to give me some wisdom on what to look for in regards to this clunk and across the board in general.
Thanks!
A failure of the U-joint in the front shaft can break the transmission casing, and other components around that area. It is something to be addressed ASAP. For the rear U-Joint, you can imagine how bad it can be as well. So watchful eye for that.
https://www.pelicanparts.com/techart...eplacement.htm
The usual stuff applies, motor mounts, intake manifold, oil separator/oil breather cover, tensioner/pulleys, thermostat, oil cooler/coolant gasket, etc. Also check for fuel tank leak, only covered for 15 years so you may already be out of extended warranty, fill tank and sniff for gas in the back seat. You should be out of the timing chain issue with the engine but you should decode the vin to make sure the serial number on the engine is out of range.
To be fair, probably the W212 is more reliable than the W211 but I prefer the W211 styling.
I love the car so far , haven't launched it because of the issues but can definitely notice the extra HP compared to the E500.
The carfax showed a repair at 40k that required the motor was pulled ...not positive what that was about but the service history was great and it has never missed an oil change in its life.
