E-Class (W211) 2003-2009
2008 W211 E350 Pano Roof Water Intrusion
Old Dec 6, 2022 | 01:37 AM
Anthony6621's Avatar
2008 E350 AMG
I have researched this car way too much. So many days. I checked all of the drains and they are working.
However I can’t find any drains on my pano roof looked up Car ID pano and it does not show any drain hose. I also removed the headliner. It appears the pano roof drains into the outside of the pillars down the outside of the windshield.
Does the pano roof have drains for this year? Passenger side leaks into front fender wheel well. The driver side leaks into cabin and footwell.
I think it’s coming in thru my windshield glass? I have researched all of the Mercedes’ drains and cleaning procedures I’m stumped. Any guidance would be appreciated.
2008 E350 with 185k miles going strong.
thank you
AG
Old Dec 6, 2022 | 10:21 AM
konigstiger's Avatar
'71 Pinto
Should be 4 drains: 2 front @ a-pillars, 2 rear @ C-pillars. One common leak point is where drain connects to frame.
Old Dec 6, 2022 | 05:07 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Have you also looked at the corner between the cowl + windshield pillar + drain hose?
Old Dec 7, 2022 | 11:52 PM
2008 E350 AMG
Thanks for the diagram, much appreciated. I Loosened corner of the headliner and I could not find the drain hose.I Did not see any drips/dribbles/ moisture from the inside sun roof area. Any suggestions where to lo look next??
Attached Thumbnails 2008 W211 E350 Pano Roof Water Intrusion-379b8ad3-d20f-4a4e-90b2-74a03bd89b4e.jpeg
Old Dec 8, 2022 | 12:04 AM
2008 E350 AMG
Video
File Type: mov
Old Dec 8, 2022 | 03:29 PM
'71 Pinto
See if you can view by removing water repellent, see attachment.
File Type: pdf
Old Dec 13, 2022 | 10:36 PM
2008 E350 AMG
I removed the repellent did not find drain hose. But I believe I see a drain hose going down A pillar by the SAM module. I also see a potential crack in roof frame I will RTV. See pics attached. Thoughts?
on a good note I was successful in replacing the oil housing gasket and cooler leaking gaskets.
thanks
AG
Old Dec 13, 2022 | 10:37 PM
2008 E350 AMG
Hos
Drain hose by SAM?
Old Dec 14, 2022 | 11:06 AM
'71 Pinto
If, in fact, cowl, windshield, AC condensation line (located side of transmission), and inspection behind left foot well panel shows fine thought glass gasket might be culprit to circumvent dropping frame. Unfortunately, frame needs to be removed for proper inspection.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
