Steering wheel column - how to disconnect wire connector
I believe it's part number A2114404509.
This is the very last wire connector to disconnect on my parts car. It appears that this is the ONLY such connector: the myriad of connector types is like it's some sort of Mensa test!
Only thing that moves is the triangle shaped parts on both sides, they bend inward slightly.
I do remember that it was a challenge to get this connector out, but after I figured how it works, it was no brainer.
I can see the image of “pinching” the top of the 2 arms with the index & Middle finger with the Thumb at the Tab at the Bottom. Presumably, this is what needs to be done, but can someone chime in to concur with this assessment?
I deduced this by way of finding this explanation on a German Site for those trying to convert to the 2007-09 Steering Wheel from thier previous Columns.
This photo shows all! When your on your back trying to look behind the Column to figure how to remove that dang Connector, you can see in this picture the preformed Aluminum Frame Notch the Connector slides into (see left of middle finger). When one removes the Module, (see what he’s holding in his hand where you can see the terminal that Connector is to mate with) which itself has parts positioned directly below the Connector making it impossible to lower/remove the connector, one is, in effect, disconnecting the Steering Module Connector in that process. In this case the WIS stating to remove the Module without detail was in fact correct! I was just about to try to take some pliers and pull that out by its lowest point tab, what a mistake that would have been!
Now my only issue is trying to figure out how to unplug the CANBUS from the A/C/Heater-Blower Box that I’m attempting to remove!
